lenses around 150mm for 5x7
Hey RJ. Thanks for the recommendations. Ive not heard or seen any of the listed so i will have to have a good look. One of the reasons i picked up the sinar shutter was to open the possibilities of using lenses that didnt come with shutters. so many lens designs.
My lenses i have atm which is more tailored for 4x5 are:
*Nikkor sw 90mm f4.5
*Fujinon nw 135mm f5.6
*Nikkor w 210mm f5.6
*Sinar Sinaron S MC 210mm f5.6
Hi,
Your lens set all have a distinctive modern multi-coated signature with modest coverage for 5x7inch. Perhaps this is intentional, or perhaps like me when I set out, I did not know any better until I forayed into the vintage whole plate [8 1/2 x 6 1/2 inch] format and discovered a repository of antique lenses lost to the modern photographer who doesn't buy lenses in inches.
if you enjoy shooting on your fast f4.5 Nikkor which has a similar limited coverage for 5x7 as your Fujinon 135/5.6, perhaps it makes sense for you to consider a brighter focussing 5x7" barrel lens like the Dallmeyer/Ross/Air Ministry 6 1/2inch to 8 inch F2.9 Pentac which illuminates the ground glass brightly. Coverage will be a push at the lower focal lengths end wide open however the low contrast of these lenses is superb for portraiture work; studio lighting and lith printing processes which bump up contrast as well as alternative processes.
They are very front heavy however your Sinar is the right camera to overcome these challenges and since you have an autoshutter, your work is mostly just to strut the camera with a lens support and adapt a 77mm filter front hood to recess the flare potential from indoor lights. On the opposite end, I don't know how you would succeed in fitting a spacer between your auto-shutter, and a wide-angle barrel lens like a Goertz Hypergon without jamming the shutter or wrecking the lens. At the ultra-wide angle lens, I find the Sinar system more painful to use once the focal lengths drop to 47mm on 5x4 inch. The shuttered lenses like the Schneider Super Angulon 90/5.6 XL is phenomenal in covering 5x7inch at such an extreme - even more because it also covers whole plate format.
The Kodak Aero-Ektar at 178mm f2.5, is nominally brighter than the Pentac (not by very much logarithmically at all) however commands a premium, usually triple that of the Pentacs.
If you are following the lens design to decide your lens, then most every Tessar will give you the inverse focal length requirement (i.e. you will need at least a 250mm or so Tessar). If you go for a double Gauss or Plasmat design, you have more flexibility for image coverage and far less interest than say, early triplets; menisci lenses or early petzvals (which are terrible for wide angle coverage anyhow!). The advantage in a studio; the large format Tessars (especially the Zeiss T* multi-coated ones) don't flare against strobes and bright lights. Compound lenses - especially wide-angles - are notorious for picking up stray light flare due to their massive angle of coverage.
On the other hand, if you are after a barrel lens with distinction and way more pretzel contorting lens covering power as a wide-angle, there are very few bright/fast aperture versions of these lenses. I'm guessing you have at least a 3 metre throw in your studio, which would mean that anything shorter than 210mm, like a Rodenstock Apo-Sironar-S 180/5,6, which is incredible for covering whole plate format [8 1/2 inch x 6 1/2 inch with movements] - comfortably covers 5x7 inch format.
5x7 inch format equates to the modern half-plate [4 3/4 inch x 6 1/2 inch] - so if you hunt for older half-plate barrel lenses (most of which were indeed ... barrel lenses) - you will find you can acquire a raft of these cheaper quality lenses than a grail lens like the Apo-Sironar S. The Apo-Germinars by Herr Docter, before his death, have exceptionally wide coverage and these incredible single coated lenses were also patented by Zeiss. Mr Cad in London was the major outlet for disposing of these lenses after Herr Docter passed away and this is how many of us in the UK came to own a set of these incredible huge coverage lenses from 65mm right up to 450mm.
It could be but that doesn't mean it should. Depends on the weight of your lenses and how much you want to risk a lens bouncing off the ground :p
Very fair point. My friend has a 3d printer. His going to make me masks for an aspect ratio of 1:55.5 I want to start shooting in. I would like to be able to clip it on my wista and sinar p2 for all three formats (4x5, 5x7 and 8x10). This will be for shooting is landscape orientation
Switching from the Half plate back to the 10x8 back with its Beattie Intenscreen the 150mm Sironar N was nice and bright, a
Interesting thanks for checking Ian. So for future reference is it possible to find out if a lens doesn’t cover the film while shooting?
I have to admit I've never tried them, as I have far too many lenses of the same focal lengths.
Well Ian, you may have a pm coming to you lol.
I just learnt that Cooke made lenses. They are legendary in the video and filiming world.
Hi,
Thank you so much for sharing. I’ve A LOT to look into.
I love the 6x12 aspect ratio so I thought the 90mm would be perfect for a wider horizontal view while slightly cropping top and bottom. As my camera before 4x5 was a mamiya rz67 proii (still have) with a 110mm most of the time. I gravitate to the 210mm when shooting waist up or 3/4 shots. They feel very similar to me. This is me subconsciously playing safe. I want to explore wider focal lengths.
I have an RB 67with the 50mm and it is a very nice wide lens, incredibly it also focuses down to 2". It is almost permanently on the camera.
When I first got my rz67 kit a decade ago it came with 50mm, 127mm and 180mm. I sold the 50 and 127 and went 65,110,140,180. Sold the 140 as I only used it a handful of times. To settle with 65,110,180. I wish I never sold the 50 as my 65mm la is a killer lens but it’s so big. In fact my rz67 kit is as heavy as my wista kit.
I've recently picked a 5x7 back for my Sinar p2 and also a sinar shutter. Im looking for a 150mm lens that i will use as a wider lens with my 210mm on 5x7 which is considered a normal lens.
I have done some research and the Schneider 150mm G-Claron f9 process lens is a option depending on how i use it. The Sinar Sinaron ws 150mm f5.6 also. Looking for options. This lens will be interior and studio based. Doing environmental portraits and staged conceptual photography so sometimes deep depth of field with more than one talent in frame.
I will be shooting colour and black and white.
Any ideas and suggestions? As i have the sinar shutter, lenses without a shutter are not a issue.
One good option I haven't seen mentioned yet is the 150mm f/5.6 Apo Sironar W / Sironar W. Those are the same lens; they differ only in cosmetic markings. Image circle at infinity is 252mm at f/22. It's always nice to have a bright lens for composing/focusing.
...Docter Apo-Germinar 150/9 W (barrel as well as shuttered versions) covers 5x7inch format
Are you referring to a 150mm f/8 Apo-Germinar W or a 150mm f/9 Germinar W? The former only has a 184mm image circle at infinity, so won't cover 5x7, while the latter is basically a modern, multicoated competitor to the 150mm f/9 G-Claron. The 150mm f/9 Germinar W easily covers 5x7 with movements when stopped down to f/22 or more.
Hey. I never knew about this lens. I know about the 150mm sinaron ws f5.6 which covers about the same image circle. One is on eBay in Germany but that price is not appealing at all.
It's the same lens. That price is indeed very unappealing, and it has no shutter. I paid less than half what that German eBay listing asks for my Copal 1-shuttered 150mm f/5.6 Sironar W version, in mint condition, but that was 15 years ago.
If you have a No. 1 shutter available, making a lowball offer to that seller couldn't hurt. Who knows what they'll accept. :)
The cells from Sinar DB lenses are not all compatible with Compur/Copal shutters, so that's a risk. The OP has a SAniar Copal shutter, so as long as it's the right one taht wouldn't be an issue. But as you say it is over priced.
If you can put up with an image circle of ONLY 231mm you can get the more common 150mm 5.6 Sironar-S (aka Sinaron-SE) which is in a copal 0 shutter hence is much lighter.
I can highly recommend the 165mm Super Angulon. I bought it as a wide angle for 10x8 but used it for the first time last week with the 5x7 back and it was a bit of sweet spot for my architectural subject matter. I found myself using it for about 80% of the time with a 240mm the next most used. It is a bit of a monster, but worth the weight !
You are very lucky. I’ve got a sinar shutter so a db lens is appealing as I doubt I will be taking my sinar p2 out on the field. The most adventurous I feel I would get is travelling to an artists studio or to a sound stage studio.
I didn’t realise about this lens. I’ve the 210mm sinar sinaron s mc so that would be a match. I’ll have to have a look if it came in a db shutter as the sinar p2 wpnt be my portable camera. Want to make use of the sinar shutter
Not quite a match.... Confusingly the suffixes weren't the same when Rodenstock lenses were sold under the Sinar label.
Sironar-N = Sinaron-S
Sironar-S = Sinaron-SE
None of the above are legal Scrabble words, sadly.
