- Oct 21, 2020
I went a bit mad a couple of weeks ago and bought yet another half plate Kodak B - actually there was method to my madness, the camera came with a 207mm Ektar in an Epsilon shutter - and a 5x4 reducing back ... and the price for the whole thing was about the same as I could get for selling off the lens and shutter.
Being as my Kodak Specialist has an ill front rise (stripped gear) I was mostly looking at the model B for parts - it actually turned out to be in rather good condition under the grime. All the other geared movements seemed to have less wear than my Specialist (which after all had been a police camera) and after I had done some 'liquid electrical tape' work on the bellows all seemed good.
I swapped the front and rear standard onto my Specialists rails - for which I have the rear extension - and everything worked much more like new.
Now the second purchase -
I have been hunting for glass for my 10x8 project build - which is nearing completion - and I saw a Schneider Symmar 300 f5.6/500 f12 for a very low price indeed with a 'broken shutter' - a Compound #4 I believe. Well, I snapped it up, thinking 'If I have to do lens cap shutter, at least I have a lens that will reliably cover 10x8'. Well when it arrived I found the only thing broken about it was the lever that holds open the aperture for focusing. If I set it to T or use a locking cable release on B it works perfectly, and the shutter speeds seem correct. RESULT!
So I made a quick and dirty lens board in the workshop with the laser cutter (three layers of ply sandwich using hot hide glue)
And got this
So I loaded some Foma 100 in the reducing back and shot this wide open with a bit of front tilt.
Somewhat of a triumph I think ...
the aperture open lever looks like it could be an fairly easy fix - it seems like it has lost it's pivot point inside the shutter -as you can still 'fiddle it to work' which I won't do much for fear of damaging something. I think it may be simply a pivot screw fallen out or broken off. At some point I may open the shutter to have a crack, but for now the work around is fine. Having a lens ready to go has given me the spur necessary to crack on with the 10x8 project too!
And got this
