5x7 Film Back
Flack
I have just printed this Rittreck 5x7 film back for my camera, I have the 4x5 film but wanted to see if this would work. Its not my design, it was on Thingy Verse made by Hawkeyes0v0. I made the ground glass from 3mm acrylic sheet and sprayed with frosting spray. This view is with a 360mm lense fitted, I have just ordered some film and a film back to try it out.
Wow this is amazing. Nice work.
Keep us posted on the progress.
That looks very nice , all I have printed so far is lens boards for the pacemaker graphics - the curled metal edges are not easy to diy but easy to 3D.
I need somewhere to site the printer for longer to try more , The film Laundry guy Awty? Has some great designs Including his 7x17 camera that I would love to do if I had space/time and less projects.
Nice one. Keep us posted on your results. It’s a great camera. Very sturdy.
that's a great result , in my opinion5x7 is worth the effort for B&W when you have the means to DIY and work around things.
The format is natural , the GG image is more comfortable toward with than 5x4 (likewise the contact print is viable) and most of all
its much more practical than 8x10 to carry , not so much the camera , Intrepids are light , it's the film holders that are bulky/heavy`
It does on my screens, and I checked by measurement.
Thanks, Ian.
I think I'm just so used to 4x5 and 8x10 that the 5x7 aspect ratio just looked so much wider in relation to its height. It's no where near so square and "box like" and took me completely by surprise. It's a proper rectangular form!
Just updated to version two, the first version was landscape only, my new one does landscape and portrait shots now.
New image with version 2 back, I messed up the emulsion on this sheet as I removed this sheet from the box , then had to put it back in the box because I was sent two more dark slides that were to small to fit 5x7 sheets in, anyway the sheet was faced emulsion down on to the emulsion of the sheet below and it stuck I had to peel if off when loading, was only a test shot anyway but not come out to bad.
so you got half plate holders as well as 13x18 ?
Yes but I sent the half plate holders back and then I got the 13x18, I did wonder if the focus would be ok in 13x18, after finding the film was a little small inside these holders, but it seems the hinge flap hold the sheet in place.
You could add a piece of low tack double sided tape to hold the film in place. I do that with some 10x8 holders to prevent the film from bulging out in temperature shifts.
