5x4 street portraits with half-frame adapter
Last weekend I tested out a half-frame adapter I've had for many years but never got around to using. This is a police mugshot adapter made by Graflex which I used on my Speed Graphic. It came in an auction lot with a 3x4 Graflex Super D but the adapter is for a 5x4 camera. It's not a universal design and only seems to fit a speed graphic.
Anyone want to guess the lens? Focal length will do. I used two different lenses for these shots. All on expired Kodak TXP 320 (ISO 200), developed in HC110 1+31 in a MOD54 adapter because I didn't want the lines I'm getting when using a Jobo 2509n.
150mm 2.8 Heidosmat off an old Rollei projector.
That's one of the lenses I used. I thought I'd help you with the file names :p . What about the other lens?
Haha. Which shots did I use the 150/2.8 on?
I thought 2 and 4.
That's why I went for 1 and 3 For a 210mm.
It would make more sense to me that a shorter lens was used for the wider shots and a longer lens for the tighter crops.
I thought 2 and 4.
You're half correct. I will give you a clue. Only one pair used the 150/2.8. The others used a different lens. It wasn't 210mm. Guess the focal length and for extra bonus points the lens maker :)
If 1+3 are the same lens the 150mm f2.8, then 2+4 must be shorter say 13,5cm?
But if 2+4 are the 150mm f2.8, then 1+3 must be a longer lens and if not 210mm then 9.5" from Dallmeyer?
And now I give up!
And now I give up!
Only one of the four pairs used the 150/2.8. The other three used a Carl Zeiss lens. Longer than 135mm but shorter than 210mm.
I got confused by pairs!
Then no.4 is the 150mm f2.8.
And no.s 1,2&3 could be 18cm f4.5 uncoated barrel lens.
Oops. My mistake. It wasn’t a Zeiss lens or 180mm. It was this one.
Still a Tessar type lens, plenty on eBay but often with no flange. Now we know it's easy to see the sharpness compared to the projector lens.
I bought it from eBay many years ago. It gives great results.
