Wide Angle Lens coice.
Loovic
As I mentioned in my previous post. My Wista 45 came with a 210mm f6.8 Rodenstock Gerona lens, not my ideal ! I am investigating wider angle lenses; I rather like the Fujinon 105mm W series. It seems the later CM-W gives one a little more coverage to work with, also f5.6. However these seem very rare lenses to acquire. The f8 has a much greater coverage – not that I will need that much for my work – but will not be as bright on the screen to allow focus. Being new (again) to these lenses I wonder how much difference there is when focusing (brightness) with f5.6 and f8.
Anyone with experience of this issue when choosing a WA lens?
For decades I used a Schneider 90/8 with my Wista without issues, even for night photography. You just need to slow your eyes time to adjust. The Wista screen is very bright. I’ve got a faster lens now but haven’t done an A & B comparison.
I started with a 90mm f6.8 Angulon, it was useless, I replaced it quickly with a 90mm f6.8 Grandagon N, which I still use. About 20 years ago I acquired a second 90mm Angulon, this one was sharp, I used it in my light weight LF kit while living in Turkey, often hand held.
Personally I find the need for a lens between 90mm & 210mm, I think it would be the same with a 105mm & 210mm.
Avoid the early 90mm f8 Super Angulon lenses in Compur #00 shutters, the shutters have no preview lever, and they are often un-repairable.
The defacto standard for wides is the 90mm f/8 Super Angulon, and most brands do their own version of exactly the same design (although the Rodenstock ones are f/6.8, same 67mm filter size) and likewise most have their own fast and heavier version at f/5.6 or f/4.5 (often taking 82mm filters). Having used both types, I would say the faster ones are definitely noticeably easier to focus in low light, but they again you pay a size and weight and filter size penalty for this. It does depend what you shoot, the environment you shoot in, and the ground glass you use. For some people if they are out shooting a 90mm f/8 in blazing sun in a desert then f/8 is fine with even a crap dark ground glass. But then again if you like mooching around damp dark British woodland at dawn and dusk then f/8 can be a struggle even with a Maxwell screen. Personally I use a Grandagon f/6.8 as a compromise although there's probably not a lot of practical difference between this and the f/8 lenses.
The 105mm f/5.6 Fuji lenses I think are intended to be used as normal lenses on 6x9, so coverage is very tight on 5x4". If you can go a bit longer then the Fuji 125mm f/5.6 lenses have more coverage and are still very small and light (and cheap), 52mm filter threads on the one I have.
I have looked at the 125mm, i am interested for sure. On the Michael K. Davis lens chart there are only two 125mm lenses: Fujinon SW 125mm f8 - filter size 82mm & Fujinon CM-W 125mm f5.6 filter size 67mm. Which one do you have, is there another not listed?
I have neither. The f8 one I think is huge and intended as a wide for 5x7/whole plate (like the 121/120mm super angulon and Nikkor equivalents). Of the 5.6 versions there are about half a dozen, one of which had an oddly oversized front filter size of 67mm, but there are other versions too, like mine with the 52mm threads.
I've got the Fuji 125/f8 and it is a huge chunk of glass. I bought it to use on 5x7 and for that it's a great lens.
The sleeper lens is the120mm f6.8 Angulon, I bought one a few years ago it's coated and in a Prontor Press shutter. Very small, light, designed for 7x5/Half plate. Images made with it are indistinguishable from those made with other lenses, like my 90mm Grandagon N, or 150mm Sironar N/
I've used the Fujinon NW 125mm f5.6 (outside lettering-on barrel) for a number of years and it has served me well. I like the fact that it shares the same size filters (52mm) with my Fujinon A 180mm f9 and Fujinon A 240mm f9.
Regards,
Edd
With wide-angle lenses, I’ve found that an extra stop doesn’t seem to make a great deal of practical difference in the centre, but the with the smaller aperture, the edges seem to be much darker. It’s possible that this is a subjective effect of course.
I believe it’s possible to get fresnels with different focal lengths which may help.
Regards,
Edd
I actually took the 125 and 240 to the Alps this summer for that very reason.
The Wista screen and fresnels are fine with most wide angel lenses to 75mm. I have both f8 & f5.6 75mm Super Angulon lenses, I'd bought the f8 for the 6x17 camera I was buying, so tried it on my Wista first and really liked the focal length. It is now permanently fitted to my 6x17 camera. I found the 75mm f5.6 at a bargain price.
I've had a 65mm f8 Super Angulon since about 1988. it is definitely not as easy to focus on the Wista as the 75mm f8. It might be easier to focus without a fresnel, but they are not removable on the Wista.
It was Linhof & Sinar who used clip in rear fresnels (on top of the GG screen, not under), and offered a choice of two, one specifically for wide angle lenses.
My Wista has been happy with a 90mm f5.6 Caltar HR (a Topcon lens badged for Calumet). It works fine on a flat board. Using a recessed board gives a bit more bellows allowance, but at the expense of easy access to the controls. I have a 90mm f8 Super-Angulon which is pretty much dedicated to a WillTravel point and shoot 4x5. Since I am scale focusing, the smaller aperture is not an issue there. Getting the scale focus set up was a pain with the f8, but perseverance won out in the end!
My 75mm Super-Angulon will work on the Wista, but it is very bellows limited. It's actually used on a 6x9 camera, mostly. I have it in a recessed board.
You are muddling the Komura LF lenses, which were re-badged as Caltar HR, with the Komamura company who made Topcon Horseman LF cameras. The Horseman branded LF lenses are marked Tōkyō Kōgaku as well, the latter the manufacturer of Topcon cameras & lenses.
It doessn't help that Calumet were once a US importer of Topcon Horsman cameras.. And then there are late Komura & Horseman 90mm f6.5 lenses that loook at first glance the same, but there are differences, coatings, and the Komura & Caltar HR , has a slightly different shaped rear barre to the Horseman lenses..
Ian, Thanks for clearing that up. I've made a note. Many (not necessarily authoritative) people in the US seem to equate Caltar HR with Topcon - it is what I was told when I bought it used, anyway. It is still appears to be a good lens, whatever its ancestry.
