But so will any other half decent contact print. He says his method will show you exactly what is on your negative and help you decide if you want to make a print. But so will any decent contact print made by other methods.
What Fred is trying to convey in the use of the Proper Proof is consistency. Many photographers will determine correct exposure for any single roll or sheets of film by doing a contact strip first, then a contact print is made after selecting the best exposure. This method may give you a nice looking contract print, but it tells you absolutely nothing about your processes. The contact print has been tailored to that
one roll of film. The PP, on the other hand, is specifically designed for a
single exposure for maximum black through clear film with all other variables at repeatable settings. Going forward, this tells you all you need to know about your process and materials through crafting the negative. Nobody has to work this way, if they chose other methods, but it sure is simple and straightforward. I could regale you with a tale of how Kodak tweaked HC-110 many years ago and stated, emphatically, that the formula was identical; the PP told another story!
Accuracy of exposure is easily checked by looking at the negative.
Sorry, I disagree. Can you tell the difference in shadow detail between a Zone II vs Zone III placement? And, I'm talking whole zones here. What if you tried, in the field, to place your textured shadow detail as low as you could get it and still retain some semblance of detail? Could you see that dark texture in the negative? Could you tell the difference, just by looking at the negative, between bits of texture along the shoulder of the curve? Again, what if you wanted to retain bits of texture into the higher values of Zone VIII and/or, maybe, into the lower region of Zone IX? Would you know by looking at the negative that you missed it and blew out these highest values?
A PP will tell you the answers to these questions. If you missed it, you'll know right away and can make adjustments. No one ever said anything was "cast in stone"; rather, it's one controlled way of working. Not trying to be argumentative here. I can assure you that after nearly 40 years of crafting LF negatives, I cannot tell much simply by looking at a developed sheet of film.
What I am trying to say is that I feel your skills and creative judgement will be honed more usefully if you force yourself to assess your negatives and your final prints, than if you follow a step by step method and set of "rules" laid down by someone else.
Not rules...just a straightforward, simple, repeatable way of working. There is nothing creative about the development of film; IMO, you should follow some sort of step-by-step method. Sure, everyone is going to make mistakes, but, if you're consistent in the rote side of photography, then you can hone your skills working on the hard parts--want are you going to put down on the film? How are you going to craft an expressive print?
A bit of an anecdote, but, I think, kind of applicable to what we're discussing here...
I remember Fred saying once, "If Ansel printed in a bikini and trout boots, I'd think it weird, but I'd try it!" The point is, what if Ansel had discovered some "magic" repeatable method for crafting beautiful B&W prints?
