- Aug 16, 2016
I am a member of the Postal Photographic Club (PPC) and one of the comments I get on my LF images is that "it is not sharp" and that is on a 5 x 7 print. I am using the camera on a Manfrotto carbon fibre tripod with the Manfrotto 410 geared head and of course a cable release. My lenses are a 90mm Super Angulon (recently serviced), a 150mm Super Symmar and a 240mm Symmar-S. I use a loupe for focussing.
Having looked at a few prints I have to agree that they do not have that critical sharp edge that I would expect and can see in other people's work.
My main film has been Fomapan 100 processed using a Jobo CPE2 in a variety of developers, ID11 1+1, Perceptol 1+2, Ilfotec HC 1+31 and Xtol 1+1. I have also used HP5 Plus and have had similar comments about sharpness.
Looking on the forum I see there are others using Fomapan 100 and those images look to be what I am trying to achieve.
I have carefully checked the camera for correct positioning of the ground glass screen relative to the film plane and all seems to be well.
When I got the camera the screen, which I think has been replaced as it does not have the Wista name on, was fitted the wrong way round, the ground glass facing the back not the lens.
Turning it over made an instant improvement but not enough for the comments to go away.
I make my prints on a well aligned De Vere 504 enlarger with the De Vere Varicontrast head using a 135mm Componon S lens that will print a sharp 6 x 7 negative satisfactorily.
So I have a few questions.
Looking at the images on here using Fomapan 100 they have been digitised for posting but have they also been sharpened post scanning?
Is Fomapan 100 a "sharp" film in general or should I be using FP4 Plus?
Does the processing method or the developer chosen affect final image sharpness?
I am loathe to use Rodinal for its acutance effect as it gives me a grain pattern I am not keen on and would prefer to stay with one of the above developers. I do seem to have to extend development times to get a negative of suitable contrast to print on a middling grade of paper so could that also affect sharpness?
That also seems to preclude using Pyro developers as they are not as easy to build contrast with.
If you need any further information do not hesitate to ask but I am away from home at the moment so may not have all the answers immediately.
I also do not have any examples to hand. My scanner is an Epson 1200 model so is not the best as neither is my scanning technique as it is not something I would ever want to use to print from digitally.
Any help or suggestions would be appreciated.
Bill
Bill
