You have some noticeable uneven development in the sky area, how are you developing the film.
I can easily spot it here on a ASUS semi tablet computer as well and it's definitely not natural, it's 5 or 6 maybe 7 darker vertical strips across the horizontal skyline. You'd possibly loose it with some simple dodging of the sky and background landscape.
A possibility is that it's distant falling drizzle which can look like this, although usually not along the whole horizon.
Are you agitating front-to-back or left-to-right? Fast or slow?
Perhaps changing to a couple of inversions every thirty seconds might help.
Do you use a water bath before the dev? Opinions are divided on the usefulness of a water bath in tanks.
Could it be that the slots in the SP-445 light-trap are behaving in the same way as 35mm sprocket holes sometimes do? This might be a possibility if the patches line up with the slots.
And yes, a bit of blackening is a good idea on the Intrepid.
