Thornton Pickard Imperial Focal Plane Two shutter Camera
Just bought this:
1730
Not sure if it's the 1907 or 1908 model yet that depends on the number of slits in the Focal Plane shutter, possibly the 1907 so speeds of 1/100 to 1/500 from the rear shutter and 1/10 to 1/90 on the front.
Essentially a Thornton Pickard Triple Imperial Half Plate camera with a Focal Plane shutter, the lens is useless but I won this for a good price. I've already got the pattern for the bellows as I have a Triple Imperial already. Should be quite a quick restoration, and fun.
Realised the camera should have bellows with tapered corners as it's post 1900, the pattern I was going to use is for bellows with square corners for an older camera of unknown make, so back to the drawing board :D
The camera itself looks in good shape the front shutter works, there's a loose aperture blade in the Emil Busch lens but I think the glass is poor anyway. The rear shutter curtain maybe salvageable sometimes I can remove the old light proofing, if not I'll just make a new curtain. The rotating tripod ring is there, they are often missing, and I have two sets of Thorton Pickard tripod legs.
Sounds ok with a replacement lens but new curtain and making a bellows I wouldn't try to do. I am ok with the basic maintenance stuff but am shy of more complex things in case I wreck a good camera. At some stage I ought to have a go as antique camera technicians are few and far between. Perhaps I'll find a cheap wreck sometime and have a bash :)
The restoration I'm doing currently is a camera that had issues, mostly caused by poor design.
1731
The front standard was broken it had been repaired before but some bits of wood were missing, so it couldn't be just re-clued. There was no joint the upright just butted against the bottom,the brass bits hold it together but the screw holes are so close to the edge.
1732
I grafted in some new mahogany, and also noticed both uprights were cracked so repaired them. Now it;s very sold.
1733
The fitting on one side for the back had an issue as well.
1734
The camera is unusual as it has a Patent swing back and the fitting on the other side moves but that puts strain on this area shown, of the 4 screw holes only one (far left) was OK the rest as a consequence the fitting was loose. It's another case of screw holes being inappropriately located, there were more :D
You have to learn how to deal with these issues so the camera is usable again. This one's not my own camera and the owner/photographer is using it for some commissioned work in a few weeks.
The area above is of the left hand side rear fitting for the back, and it's now solidly back in place.
1735
Just finishing making a new lens board, then the bellows :D
Coo that was a breakage waiting to happen, I'm surprised that a camera of that age didn't have a proper joint, the repair looks great. I can cope with getting that far but I just wouldn't attempt bellows. I could see a whole load of wasted material, if I did :)
Nick
Perhaps an account with pictures of the bellows-building? It must be a subject of interest to most LF users.
What material are you using for the bellows Ian?
It depends on the camera, I use bookbinding leatherette for the outside and I've four options for the inner lining one of which I make myself and mainly use for shutter curtains. The other three are very thin shutter curtain material (Japanese0 designed for 35mm/120 cloth curtain SLRs (I have quite a decent sized roll) which I got quite cheap (long story), the other two are high tech blackout materials.
There's plenty on the Internet already on making bellows however there's some nuances missing when it comes to the design, there's a few trade secrets that I've spotted.
Thanks Ian. I made my last bellows out of real leather, but have thought I might try bookbinding leatherette if I did another one. My son works near Ratchfords in Stockport, so I may send him round with a paper template!
If anyone is thinking of making a replacement bellows for an old folding field camera, then it is a big help if you have the old bellows to take measurements from. The reason is that the folded up bellows have to fit into a space that , at face value, may not seem wide enough. If the total thickness of all the bellows pleats is, say, 20mm. then how do the bellows fit into a space that is only 15mm wide, in order for the camera to fold up? The answer is that those Victorian camera makers were cunning and clever devils. By varying the width of the pleats, they made bellows that would fit inside themselves, and so take up less room than you might at first think.
