Nikkor W-150mm f/5.6 Lensboard Query
gnomus
I am starting to put together a 5" x 4" kit, built around an Intrepid Mk 4 camera (only just ordered, so some way off as yet). I have bought a Nikkor W 150mm lens for it. It arrived this morning. The lens seems to be in excellent shape, and it all seems to work - I don't know how accurate the shutter speeds are on it, of course.
The lens came mounted on a Wista board (it has a little shield logo on one of the corners. I believe this should fit the Intrepid (please let me know if I'm mistaken). My only query concerns the fitting of the lens to the board. When I adjust the shutter speed (using a knurled ring that goes around the lens) the entire lens (both bits in unison either side of the board) rotates slightly in the board. To work around this, I can hold hold the shutter release bracket. I can adjust aperture without the lens rotating in the board, but shutter speed seems slightly stiffer (I don't think it is abnormally stiff though).
The lens seems to be screwed together tightly enough. Certainly it does not seem to want to tighten any more (not that I've tried to force it). I have two questions: a) does what I describe sound 'normal'; and b) if not, how do I go about tightening the lens down to the board? I've never had any LF kit before so apologies for my beginner questions.
Thanks in anticipation.
Steve
PS: Do people put protective UV or IR filters in front of these lenses or are they best used 'bare'?
Perfectly normal.
The lens cells screw into the front and back of the shutter and play no part in holding it onto the lensboard.
The shutter is held onto the lens board by a small ring at the back. This needs to be fully tightened, but not excessively so. It will have notches in the edge and you can get tools which fit these notches, but the rear lens cell must be unscrewed for access. Handle it carefully and take the opportunity to blow away any dust, but gently.
The ring will have a small annular step, which fits inside the hole, to centre the lens accurately.
Some lensboards have a small notch in the hole and there is often a small, protruding, apparently functionless screw on the back of the shutter which fits into the notch to prevent rotation altogether. If it's absent, someone has removed it. If you try to fit a lens with the small screw in place, to a board without the notch, the shutter won't sit properly flat. It's quite easy to use a needle file to make a notch, but do this only after you've established exactly where the little screw will fall.
You'd usually assemble the whole thing with the word Copal centred at the bottom, but there's no absolute rule about this and you're free to choose whatever you like. If you do this, first check that you can operate the viewing lever, the cocking lever, that the cable release is not obstructed, that you can read the scales, and that your camera will fold flat. (If you'll be folding the camera with a lens in place.) As you're new to LF, it's probably better to follow convention.
I do hope this all becomes clear when you have the lens in front of you.
I suspect, but I don't know, that most people use their lenses without a filter, unless they need one for a particular shot. It you will often be out in inclement weather, some kind of protection for the front element might be a good idea.
Opinion is divided on the optical benefits of ostensibly clear filters. Most of the advice is concerned with small format cameras. I believe that a UV filter can help to remove blue casts in very bright sunlight or at high altitudes, when using transparency film. An IR filter is a different thing altogether and blocks visible light.
Other members will have more and better advice than mine on using filters.
Thos video will show you clearly how to mount a lens Steve. Be aware that the 'key' that Fred uses for tightening the locking ring are a rare as hen's teeth and very expensive if you can find one. The alternative is cheaper but can be tricky to use.
1757
Late edit: I notice that Amazon has a Rodenstock lens key advertised at the moment, probably the cheapest I've seen in a while.
That's a really good demonstration. Fred has quite a few short helpful videos.
Thank you, David for that extremely comprehensive reply. I'll look for one of those tools and may (or may not) have a go at tightening the ring. But I may well test things in the field first - if it doesn't leak light I may leave well alone, given that my 'interventions' often have unintended consequences. Unless you'd advise against that.
On my lens, putting 'Copal' at the bottom, results in shutter speeds being bottom left and apertures being bottom right (as I look front on). My lens does not have a cocking lever as far as I can see. It has an open and close lever and then the shutter seems to 'autocock' (if that's a word). And you cannot fire the shuter if the lens is open.
I've also noticed that the lens is offset slightly downwards on the board. I don't imagine that's a big problem. Some film holders arrived today, so I'm just waiting for the camera now before I can try things out.
Thank you Keith. I've been able to find one of these keys on Ebay for a few quid less. I take it you think I should tighten things up then?
The normal Linhof lensboard has the hole for the lens below centre. This is something to do with the construction of earlier models of Linhof cameras. Other members will be a able to supply much more information on camera models and their history.
You can get centred boards, mainly from China, if it's a problem. We seem to be converging on Linhof and Sinar as the two standard types for lensboards on new cameras.
You can, with a little care, poke the ring round with two small screwdrivers. Three hands will be useful as with most LF operations. Or you could bung on a bit of tape (black tape inside the camera), until your courage is fully assembled.
It sounds as though your lens has the small 'locating screw' that David mentioned and it is canting the lens on the board. Carefully remove the lens and look for the small screw/peg on the rear face of the shutter assembly. If it is there then you have the option of a) removing it or b) using a small needle file to make a corresponding locating slot as David mentioned. Option b) is the prefered one but you need to orientate the lens to suit your particular requirements before cutting the slot.
Sorry Keith. I probably wasn't clear. The lens does not appear to be canted. Rather the lensboard has an offset hole.
If your lens doesn't have a locating screw you should be able to tighten everything up by hand without using a lens spanner. I did one myself the other day when I changed a 210 Apo Symmar from a Wista board to a home-made one. First decide on the final rotational position of the lens on the board. Then hold it in this position and screw the locking ring up by hand as tight as you can. Then turn the lens a few degrees anti-clockwise, tighten the locking ring again, then grip the locking ring and the board with one hand and screw the lens clockwise. It should tighten up nicely and, with luck, end up in its chosen position.
What is its best position? Well, you definitely don't want any controls on the top where you won't see them with the camera sitting on top of a fully extended tripod. Unless you are seven feet tall you want the controls on the side.
............ Then turn the lens a few degrees anti-clockwise, tighten the locking ring again, then grip the locking ring and the board with one hand and screw the lens clockwise. It should tighten up nicely and, with luck, end up in its chosen position.
This is a method I think we have all used in the past, for me it was in the field and born of desperation when I couldn't find my spanner in the bag. :rolleyes: Using the front cell as a 'spanner' like this exerts far more torque than a conventional lens spanner so it is easy to overdo the tightening but also bear in mind that you are tightening the front cell cell into the shutter barrel at the same time - not the best idea imho.
I think you are splitting hairs here Ken, though perhaps I should have said screw the shutter...
It's the shutter that's attached to the board and the lens cells screw into the shutter. A different lens may be very much tighter and if you need to remove it for any reason, you may have difficulty. Almost certainly, it's best to sell the car and get a lens key.
I agree that, for a simple flat metal plate, they do seem expensive, but much cheaper than a damaged lens or shutter. (Intrepid, are you listening?)
Even with a key, you will probably need to do the Haithwaite Shuffle to get it in exactly the right place.
..........Even with a key, you will probably need to do the Haithwaite Shuffle to get it in exactly the right place.
With advancing years, and my ever-present friend Arther Itis, this sums up my mobility very well David but how did you know (have you got a spy-cam set up in my home somewhere? :eek::)) so all my LF lenses are set up on their lens boards with the speed and aperture scales on the left and right side.
My secret is out. I am in fact the head of an Empire of Evil, collaborating with an even more totally evil alien race, exiled from a distant but evil star system (...for excessive zeal and too much curiosity). Our invisible and undetectable micro-saucers see everything, everywhere.
We love introducing unexpected light leaks into large format equipment, but when we are bored, we interfere with developers.
The Cottingley Fairies was one of our better-known efforts. Our next project is to enslave and dematerialise all DSLR owners.
OK - I'm back! I've been watching YouTube videos and such like. I still don't have the camera, but have been playing around with the lens (the wrench hasn't arrived yet either).
I have a couple more questions.
My lens has two cable release ports. One fires the shutter. The other appears to replicate the Open/Close lever on the lens. Whatever I have the lens set to, this second cable release will open the lens fully. That is, it is not a way of stopping down to the selected aperture. As such, I have no idea what this is for. (Was that a question?)
On the YouTube videos people will focus the lens and then stop it down to check DOF. As far as I can see there is no way of closing the lens down to the selected aperture other than to put the shutter onto Bulb and then keep the shutter depressed whilst I check.
Is that correct, or am I missing something?
What shutter is the lens in, there were some specialist Prontor and Copal Press shutters only made for a short time, they are quite rare but do surface every now and again. A photo might help.
I have heard of LF shutters with open aperture control as well as the normal shutter preview but never seen one.
Thanks Ian. The shutter is a Copal 0. Between the aperture and shutter controls it says just, 'COPAL'. 180 degrees around from this it says, 'for WISTA NO.O' (I know that it will be a 'zero', but the font used on the lens body is identical). The lens itself says 'NIKKOR-W 150mm 1:5.6 720648'. I'm happy to take a couple of photographs. Is there anything specific you would want me to photograph?
OK, it's not strictly what we normally call a Copal #0, it's a Wista 0.0 Press shutter modified by Copal for Wista. The second cable release socket connected the shutter to the camera back (not sure which Wista models) and the lens would automatically stop down when a film holder was inserted.
Musashino was a camera manufacturer in Tokyo they mad Rittrek cameras after WWII, a very nice compact and light metal bodied 7x5 field camera and a 6x6 SLR, also Shanel shutters. They had set up a seperate distribution company Rittrek Trading. The manufacturing side went bankrupt in 1969, production of the Rittrek 66 was taken over by Norita, Rittrek trading took over filed camera production forming a a new company Wista in 1972.
In the 1970'snand 80's Wistar had their own rebranded range of Wistar lenses, mostly made by Nikon, as well as their Wista press shutters modified for them by Copal.
Like the Ibsor and later Prontor press shutters the Copal & Wista press shutters are self cocking, this limits the top shutter speed usually to 1/125. While this helps make them faster to use than a standard Copal/Compur shutter you still have to stop the lens down manually after focusing, the Wista press shutter adds auto aperture. Quite outside Japan and the US.
Thanks for the information. How interesting. The top shutter speed is indeed 1/125 (which I suspect won't be an issue) and it is self-cocking. The lens stops down when the shutter is fired. The aperture goes from 5.6 down to 45. Do you foresee any issues using this with the Intrepid? I got my fortnightly 'update' this morning, so I imagine I'm still a long way off having the camera.
