I am starting to put together a 5" x 4" kit, built around an Intrepid Mk 4 camera (only just ordered, so some way off as yet). I have bought a Nikkor W 150mm lens for it. It arrived this morning. The lens seems to be in excellent shape, and it all seems to work - I don't know how accurate the shutter speeds are on it, of course.
The lens came mounted on a Wista board (it has a little shield logo on one of the corners. I believe this should fit the Intrepid (please let me know if I'm mistaken). My only query concerns the fitting of the lens to the board. When I adjust the shutter speed (using a knurled ring that goes around the lens) the entire lens (both bits in unison either side of the board) rotates slightly in the board. To work around this, I can hold hold the shutter release bracket. I can adjust aperture without the lens rotating in the board, but shutter speed seems slightly stiffer (I don't think it is abnormally stiff though).
The lens seems to be screwed together tightly enough. Certainly it does not seem to want to tighten any more (not that I've tried to force it). I have two questions: a) does what I describe sound 'normal'; and b) if not, how do I go about tightening the lens down to the board? I've never had any LF kit before so apologies for my beginner questions.
Thanks in anticipation.
Steve
PS: Do people put protective UV or IR filters in front of these lenses or are they best used 'bare'?
Steve
