Checking your camera's stability.
We all know that a large format camera on a tripod is potentially less stable than more compact medium format and 35mm cameras. And some designs of large format camera are less stable than others. Tripods and tripod heads also vary in their degree of rigidity and resistance to vibration. The question is, what do we do about this? What steps can we take to increase stability and reduce vibration when we fire the shutter to take a picture? Has anyone, for example, done the classic sherry glass test to detect possible vibration when the shutter is fired?
I have had the odd large format print that wasn't sharp because of what looked like camera shake. This has led me to do a bit of testing, and it can be a bit of an eye opener. I think I now know the best way to use the kit that I've got, but would be very interested in others views on this subject.
An important feature of tripod heads is the size of the platform, I'm now using an old Gitzo head I picked up just before Covid at a camera fair. I'd post an image, but with this heat I don't want to open my darkroom door as it's well insulated and will be cool. The head is quite old, and the platform is around 6" long and 4", this really helps with stability.
Yes, a bigger platform must be more stable. Some QR plates seem intended especially for very tiny camera, so if you use them, a good amount of contact is needed.
Gitzo seem to have discontinued their best ones in favour of a huge menu of ball heads. No doubt they are guided by the wisdom of their marketing department. Is it be possible that image stabilisation is causing tripod heads to evolve into lighter and more fragile species?
A good way to test, if no sherry is available, is to put one of those pen-shaped laser pointers on the camera and see what happens to the little red spot on a distant wall. I found that just moving from one foot to the other next to my camera, on the ordinary wooden floor at home produced more jiggling than I imagined.
Steve O’Nions (qv) mentions using a laser pointer to create a useful focusing target in gloomy conditions.
Yes, the bigger platform must help, but a big platform won't save the day if their is any movement in the head itself.
David, no sherry available? Use water.....And if the design of the camera makes it impractical to balance a sherry glass, you might use a metal screw top lid off a glass jar. Or a laser pointer.
David, did your laser pointer move when you took hold of the cable release prior to firing the shutter? And did it move when you fired the shutter?
I’m quite gentle with the cable, so it kept still. A tiny, tiny quiver with the shutter sometimes, but not always. My exposures are generally in seconds, so no problem in practice. This is with well-maintained Copal shutters. Inserting the dark slide and pulling out the sheath causes obvious movement. It all takes a little while to settle, but waiting a little while is good practice anyway. I haven’t tested it, but long bellows extensions might be more susceptible. Even DSLR photographers use their 2-second delay to get better stillness, despite stabilisation.
I was surprised at how much movement I created by moving about.
By being gentle, it’s possible to get away with very feeble equipment. Unless there’s wind of course.
Interesting comments David. It sounds like you are well organised.
I have found that cable releases can be a potential problem. Some are so stiff you can almost push the camera over with them. Flexible ones are obviously better. Even better is a rubber bulb release with a very flexible length of thin rubber tubing. The one I have was originally a remote release with a very long length of rubber tubing. I cut this down to 12 inches.
I deny being well-organised, but I do have a lot of experience in making mistakes.
As you say, some cable releases are remarkably stiff. The plastic-covered ones become amazingly rigid in the cold. It seems to me that the important thing is to maintain a good curve on the release. I like a bulb, but for some reason, seldom use one.
