I thought that I'd start a new thread to illustrate 'step and repeat' images. This technique allows a lare format camera to capture multiple images of static subjects which can then be stitched together to produce a single image. Whilst it has numerous disadvantages, it also enables lenses to be used to shoot images at up to the 'format' that they were designed for. It allows evaluation of older lenses which would otherwise be very expensive shooting film. It has limitations due to the 'throat' of FX digital cameras (MF digital backs are too expensive for me) but so far I have found that it can produce surprisingly good results.
The Sony is a 4 image stitch shot on an 1864 stereo lens by Grubb's of Dublin. I haven't calculated the aperture, but its quite well stopped down. Using a smaller stop degrades the image so I'm probably working at F/22-32 and this is likely to be optimal for this lens. The result is very acceptable and the small amount of chroma is easily removed in Photoshop.
The scene is of Lochranza and has history in that it was photographed by Thomas Annan of Glasgow in 1862 too (a print is in the National Library in Edinburgh). He is known to have owned and used a Grubb lens which he may well have used on Arran. The image is a 16 image stitch and is something around 6x9cm or so (1/4 plateish). Again well stopped down.
