Hello from Madrid
TallBill
It's difficult, large format. I've spent days and over 100 euros tracking down light leaks. I will get this right, I will......
Bill Dixon.
Welcome, can we help with finding the light leaks ?
I learned a lot while solving this problem. Thanks however to Ian for the offer, which is much appreciated.
I carefully inspected my camera, a wooden field type, for loose fitting items, bad alignment and worn seals and put black tape and black paint here and there for a totally light-tight job. I tested that with a small hand-torch placed inside the bellows and went into a darkroom to look for any escaping light. It surprised me just how much there was when I started.
Then I reviewed and practiced my method of loading film into holders, placing holders into the camera back and removing and reinserting darkslides without nudging anything open which shouldn't be. I checked my method of loading film into spirals and handling the developing tank.
At one stage, I developed an unexposed sheet, like Henri Becquerel, to see if I had a bad batch, which reproduced the error, thus eliminating the camera and holders. But it wasn't the film, because I tried the same with a sheet from a different batch and got the same result. It turned out to be the developing tank, which I had bought second hand, since my existing tank wasn't big enough. It had a very fine fissure in the sidewall, which also explained the greater than usual shrinkage in the quantities of developer and fixer I was getting.
This also taught me that we see what we are looking for. I saw a tank, and assumed it was a good one. I bought a brand new tank, which I have since tested.
Now I can get on with taking photographs of the very fine scenery in and around Madrid, and other things.
Bill Dixon
I'm glad you solved your light leak problem, Bill. Something to keep an eye on is the black tape along the bottom of film holders which acts as a hinge. That will wear down over time and will let in light. I've been replacing the tape on a bunch of my holders recently with book binders tape.
