Try resouping the neg in alkaline solution AFTER you have completed the dev process.
Thats to say, dev, stop, fix, wash ( although a quick rinse will suffice to clear the majority of residue fixer), then soak the neg in a new solution of developer ( strength can be stronger than what you developed with).
Agitate gently and after a few mins , perhaps as long as 7 or 8 minutes you will hopefully see the magenta spots dissapear if they relate to a similar problem that i experienced with the anti halation layer.
My advice to you is basically a copy of what Foma themselves advised to me.
After the second souping in dev solution , simply wash like you would normally before drying the neg.
As the neg has already been fixed , you can do that additional stage in daylight .
Hopefully this will resolve your problem, if not then I can recommend contacting Foma directly .......They were very helpful!
EDIT: I see that
RLeal mentions an anti halation layer issue too.
