Lens Hoods
Reginald. I’ve misled you shamefully. It was venison, not beef.
A minor matter, however is that I was talking about flare in a spot meter. Quite the converse of flare in a camera. Flare elevates the meter reading, resulting in overestimation of subject brightness and consequent under exposure. This is particularly true in bright light where flare is most likely to happen. It’s exacerbated by the fact that brighter light means darker shadows. I hope this is a bit less garbled than before.
Thanks for clarification, David.
Finally, at least to me, both either the spotmeter or the camera lens react to non imageforming light.
My own reaction in critical situations is bringing the inlet from toilet paper roll in front of my spotmeter (lets say a lens hood to a lens on a fixed standard) and applicating a flexible compendium to cameras with movements.
After buying this Shen Hao 45A I immediately trashed the useless-if-moving-my -standard lenshood but rescued a fantastic lollipopfilter holder.
That's really nice. What's a lollipopfilter holder? How did you size it so it doesn't vignette?
With 67mm the filters themself are bigger than my 4x5" and 5x7" lenses so vignetting isn't a problem.
Imagine a threaded glass filter with a handle/shaft which then will look like a huge lollipop:)
Having a deeper look to my picture will show the Linhof labeled handle of the filter.
Just stick it quick to the holder - no threads needed there.
Rather like a Sherlock Holmes’s magnifying glass, perhaps? The red filter that most enlargers are, (or were) fitted with, works in the same way.
Something like that :)
I have found this:
I totally forgot that the hood first hasn't been as useless as said before; it has had to hold a Schneider box filled with a square infrared filter. Which I later have lathe machined to a round..
Something around 70mm in diameter.
I redesigned the original holder-to-the-lens adapter in this way that I now can throw in one 67mm filter to it's backside (between lens and holder).
Here is a picture wher the Linhof filter holder filled with a threaded 67mm glass filter is shown, unfortunately too dark a bit because the spot has been on my own creation of a holder.
Maybe I'm missing something, but what has fitting a lens hood to an LF lens got to do with using a handheld spotmeter?
Same reason to try and prevent lens flare, which can give false spotmeter readings. It's never been an issue with my Spotmeters though.
Ah, I see. Like you, I have never found that to be a problem with my spotmeter. If it were to occur, I guess I would just curl my hand around it for the few seconds it takes to take a reading.
