Nikon 90mm sw 90mm 4.5
We can rule out vibration, because that would be more evident in the 180mm shot.
Perhaps you could try a cheap and cheerful test on the lens? A Post-it note or a chinagraph might be useful. These are to mark the zero-adjustment starting point.
Focus as well as you are able on some suitable well-lit high contrast subject, using a decent, carefully-adjusted loupe.
Unscrew the rear element by half a turn. Examine the ground glass and re-focus.
Another half turn… and so on.
The threads are sufficiently fine to replicate shimming and sufficiently well fitting not to droop.
Make notes each time, of course. If there is an improvement, keep testing until it gets worse again.
Obviously, you can refine this with smaller increments and if there is any improvement, you can finalise by taking actual images.
After that, there is no immutable law that the shims must be made from metal. You can easily cut one out of stiff card, or build up the required thickness with several sheets of paper.
Another, and more pessimistic explanation is that one or more of the elements has shifted. This almost certainly needs the help of a grown-up.
Added later. For more accurate focusing, you might try the parallax method. Replace the normal GG and Fresnel with clear glass. Make a cross on the centre on the lens side, with a fine black pen.
it might be convenient to apply a few strips of matte tape nearby to use for focus.
The method is that you look at the very small part of the image visible through the lens. You will not see the whole image. Now you move your head sideways, back and forth. The image will appear to move, relative to your black cross. When the image does not move, then the camera is focused on the same plane. Rather cumbersome-sounding, I know.
As you are taking no photographs, it does not matter if the clear glass is the same thickness as your normal screen, but if you are, then the surface should be in the same plane as the film surface in the dark slide. This will depend on the construction of the individual camera.
Good plan.
What if I remove the fresnel screen and just use the ground glass?
Would that still work. I'm asking as I don't like the fresnel because it appears to add lines to the screen when focusing with a loupe.
I too have the Nikon 90mm F4.5. Took some photos recently on my Sinar and it is one of my sharpest lenses. It sounds like you might have a faulty one. All I can think is that the rear element is wrong, it should be quite bulky. It should look like this.
Good plan.
Where is the fresnel, front or rear of the gg screen. One reason I suggested the lens be tried on a different camera is in case there's a register issue.
I serviced a Speed Graphic for a member here a few years ago and the previous owner had incorrectly placed the fresnel under the ground glass. I've also seen the screen the wrong way around in a camera.
A good suggestion, but if, why would the 180er lens perform sharp..
Assume 1.5 to 2 mm shift in focus, with a 180mm lens is minimal but will still show as slightly out of focus, but is far more critical with a 90mm by a factor of 4, so like the focus of the 180mm being off by 6 to 8mm.
Yep, that's what my one looks like.
The fresnel is, as far as I can tell, between the ground glass and the rear lens group (if that makes sense)
I have to say, if the fresnel was in the wrong place then I'm guessing all my pictures would be soft regardless of lens.
Does the shutter say Nikon on the side and possibly SW 90mm f4.5. The marking on my 240mm W in aCopal 3 are between the shutter release arm and preview lever.
The question is was the lens shimmed and they got lost when fitting or removing from a lens board, at some point. You would need someone with an optical bench to test the lens to check if shimming the rear cell improves sharpness.
There are occasional lenses that slip through QC, I was given a 150mm f4.5 Carl Zeiss Linhof Tessar a few years ago that is not sharp at any aperture or distance, now I also have an East German CZJ 150mm f4.5 Tessar that's excellent.
I have a couple of shims and they are 0.15mm & 0.60mm thick, they won't fit your shutter though.
The shutter does indeed have Nikon written on it along with a description of the lens.
Yes.
Obisiously hasn't been my day yesterday.
Would the Schiender Super Angulon 90MM F/5.6 XL-110° be a suitable alternative?
I'm struggling to find any data on the above though.
A quick test. With my 184mm Wray Lustrar the difference in critical focus between approx 8ft and around 40ft is around 12mm extension. However with my 90mm f5.6 Super Angulon its more like 2mm.
So if the fresnel is in the wrong place that's a very significant focus shift with the 90mm but far less so with the 180mm.
From memory your camera is a Linhof Kardan Color and they did not come fitted with a fresnel, so it may well be incorrectly fitted.
A Super Angulon 90MM F/5.6 XL-110° is overkill, theses are large expensive lenses.
I no longer have the Linhof, I have a Toyo 45A.
I'm fairly sure the Toyo comes with a fresnel as standard.
The thing I don't know is which way the fresnel should be facing.
I admit the lens I found is quite pricey but I can probably offset that using the Nikon as px.
I'm beginning to wonder if my fresnel is fitted the correct way round.
Anyone know if the grooved side of the fresnel should be touching the glass or facing away from it?
On the Toyo the flat side of the fresnel faces the lens, the grooves against the ground glass, I have the same back on an older Toyo Half plate View camera, I only have the 5x4 back..
If you remove the fresnel then the ground glass will not be in the correct position, and would need shimming. The Toyo screen and fresnel is very bright and easy to use, without a fresnel it is harder to use.
That's the back I have, so yes incorrectly fitted.. A fresnel is a lens so if mounted incorrectly it will definitely affect the focus, so that may well be the issue here. A typical fresnel for a view camera is around 2mm thick, the actual grooves are very fine. I just tried one from a Speed Graphic and it has a focal length of approx 6 inches so the wrong way around and correct focus will be compromised.
You will have to try it and see.
It's now top of my list of things to do.
Thanks for the help.
Tony
