- Dec 19, 2017
Pyrocat HD can be used with an acid Stop bath - at half strength, and a typical fixer like Hypam, or Ilford / Kodak Rapid fixer, they have no effect on the staining.
One chemist on Photrio checked the stain density differences using a water stop and an acid stop bath with PMKl some years ago, he found a 0.1 higher density with water, and concluded that it was likely to be because development carries on longer with a water stop/rinse, compared to an acid stop bath. It's also likely there's some dichroic fog with a water rinse and an alkali fixer, which would be similar in colour to the Pyrogallol stain.
Ron Mowrey/PE on Photrio, who devised some of the Alkali fixers like TF-2, TF-3 and TF-4, stated that you always needed to use an acid stop bath with an alkali fixer as he saw dichroic fog in early tests. Essentially with a water rinse the alkali in the fixer causes residual developer in the emulsion to begin working as the film is fixing, before it clears.
My experience with Pyrocat HD of 17 years plus, is also as an alternative Pyrocatechin re-developer for Ilford IT-8 toner, something I’ve used a few times over the years, amazing Olive black tones unlike other toners, I must have first used it in the very late 1970s, but the simple Pyrocatechin redeveloper has a very short tray life, Pyrocat HD works just as well and gives the same tones, lasts a bit longer.
My point though here is after trying water stop, and acid stop bath, acid fix and alkali fix, no-one of these affect the stain which is very stable.
We have to take inexperienced peoples comments with a piece of salt, users or sellers.
A chemist, to PhD level:
The stain caused by pyrogallol, catechol, and hydroquinone consists of oxidation products (polyphenols) of the developing agent. These are lumped together under the term humic acids. The stain is dark coloured and insoluble in water. I doubt whether the stain once formed can be bleached by the bisulphite ion in the fixer. The stain that forms in developer trays is the same substance, and it is very difficult to remove, requiring a strong dichromate bleach.
