T
Timothy Klein
Guest
First, regarding the center tab on the bottom: it seems that some tabs have too much flash left over from the molding process. While the production people are supposed to check this, they miss some. I fix it using 120 grit emery paper. This is a very thick, industrial version of sandpaper. Don't be afraid to get a bit aggressive! You should be able to slide a business card under the tab when you're done. (If you get carried away and break off the tab, just let us know; we'll replace it under warranty.)
BTW, I shoot FomaPan almost exclusively. I've only seen the issue once and fixed it easily.
Regarding 8x10 and the Orbital concept. We've been looking at it in conjunction with our SP-1810 concept.
Our current design (no prototype yet) would handle one sheet of 8x10, two sheets of 5x7 or four sheets of 4x5. It is "semi-water tight" but would be "rocked" for agitation. One of our concerns: will darkroom fanatics accept a non-inversion "tray style" agitation technique?
We hope to be testing it soon.
Also, check out our new gallery page on our website: https://shop.stearmanpress.com/pages/feed
