S
SteveInNZ
Guest
I've recently bought a Thornton-Pickard Half-plate Imperial.
The shutter isn't complete and it's missing the large release bar that gets lifted to fire the shutter. I see that it was available with either a pneumatic bulb release or a cable release.
What are my options for the pneumatic release ? I currently use a modified bulb and hose from a blood pressure cuff with Kodak shutters but what can I use at the shutter end on a TP shutter ?
With the cable release version, would a modern cable release work ? Does the release get threaded in or is it permanently attached ?
Are there different standard sizes of the shutter box (if that's the right term) ? When my camera is folded up, the shutter isn't central in the tripod hole to the point where the speed release knob is hitting on the tripod base. Also, looking in from the back, I can see that there's a light leak and some unpainted wood that infers that the hole in the lens board and the shutter box aren't a matched unit.
Steve.
Steve.
