- Aug 29, 2020
Hey peeps,
I did a test roll of fomapan 200 to see what the latitude of the film is. It was under very controlled conditions, strobes.
I rated the film from EI25-EI800. Development was great no issues there. What I found on all frames is salt and pepper like spots. It’s all over, like a layer above the image. Under a light box I noticed them. I scanned the very first one and was amazed that it’s all over the place. It affects you finding the black and white point and editing the frame.
My question is, has anyone experienced this before and is this also something that happens on fomapan 200 sheet film? I bought a box of fomapan 200 but wanted to test on roll film with my roll back instead of burning through sheets.
Here is a cropped section of the image. The salt and salt dots is on all frames no matter how I metered.View attachment 5051View attachment 5052
Fomapan 200 in 120 rollfilm has had known problem with emulsion flaking off the negative. When I contacted Foma, they explained it's because the emulsion is a hybrid of cubic and t-grain and sometimes this causes the small bits to fall off. They said they were "working on the problem" but that was well over a year ago. I had a whole brick of the stuff that was bad and Foma made good on it.
The problem expressed itself even though I used water stop bath.
HOWEVER, if that were the case, I'd expect to see black spots in the positive, not white ones, so I am at a loss to explain this.
N.B. I have not seen this problem with 5x4 or 35mm F200.
