- Oct 17, 2023
Having been somewhat less than impressed with my Nikon 90mm 4.5, here is my new (to me) Schneider Super Angulon XL 110 Degree 90mm f5.6.
It looks pretty much as new asides it has no box.
I'll be film testing it tomorrow, wish me luck.
It will be an easily worthwhile investment if it prevents the risk of damage and rigmarole of un/screwing the rear lens group every time you wish to change lenses. Otherwise, I don't see the lens getting much use realistically out in the field.I have to admit I did consider an even wider lend but, like you, I doubt I would use it much.
The only downside is that I have to remove the back end of the lens to fit it as the rear element group is very large.
If it works out in terms of image quality I'll invest in a blank lens board and offset the hole by about 3mm.
