When to change to a macro lens?
Dom Palubiski
I am shooting more and more at a sort of 'mid-marco' range and was wondering if there is a reproduction ratio where it becomes advantageous to change from a standard lens to a macro lens?
For example, most macro lenses are optimized for 1:1, and (since I know/own the Nikon lenses) the W series are designed for optimum at mid-range, and the M series at infinity. What sort of enlargements is it worthwhile swapping between lens types to get the best image quality? Basically I don't do 1:1 range but would the price of a dedicated macro lens be worthwhile?
Thank you in advance.
...(since I know/own the Nikon lenses) the W series are designed for optimum at mid-range...
How have you established that about the Nikkor-W series? Based on your own experience/testing? Something written somewhere? Or just assumption given that competing plasmats from Rodenstock and Schneider had documented MTFs specified at reproduction ratios between 1:10 and 1:20?
I've never encountered anything that discussed distance optimization of the Nikkor-W series before, so you've piqued my curiosity. :)
Kodak sold the 203mm f7.7 Ektar for general use and up to 1:1 it's a very sharp small lens. Dialyte lenses are excellent from Infinity to 1:1 due to their design, these Ektars were made in the UK as well as the US. The UK versions are in standard Compur/Prontor #0 sized shutters, most US versions a non standard Supermatic kodak shutter except a few very late ones in Compur #1 shutters.
Schneider sold their Componon lenses in shutters as Macro lenses, they aren't expensive. I have a 135mm shutter mounted for close up work as an different FL alternative to the Ektar.
I use one of my 203mm Ektars quite a lot in my light weight LF kit and it always amazes me just how good this pre-WWII design performs today. It started life uncoated as the 8"/203mm f7.7 Anastigmat but like all Dialytes has 6 internal air glass surfaces so had low contrast due to flare, it was renamed Ektar when coated and now has excellent contrast.
I read about the Nikon lenses somewhere (but I admit I forget where). I couldn't find it again for this post but I remember it being stated that 'the 300 mm Nikkor M series is a lightweight landscape lens that is optimized for infinity to simplify its design, compared to the more general range optimization of the W series' (might be paraphrasing a bit there). If there is more concrete evidence of that id love to see it as well.
Being used to how lenses are today I would have thought all the big companies would just aim to reproduce the same lens their competitors were making but their own, like the holy trinity lenses and such for modern DSLRs. So maybe it makes sense if they have similar specifications?
I have heard about the Ektars, might have to look into those lenses.
The disadvantage of the 300mm Nikkor M on a 5x4 camera is with many cameras there's not sufficient bellows extension to focus particularly close, and with the bellows fully extended the camera becomes much less stable.
I tried doing some close up work around 1:2 with my 240mm Nikkor W last year but it's a touch too long *again too much bellows extension is needed), my 210nn Symmar S or 203mm Ektar is better in this respect.
Choice of camera helps, my Wista 45DX or Super Graphc have Double (bellows) extension essentially that means 200mm/12" twice the typical normal focal lenght 150mm/6" lens, where as my MPP Micro Technical cameras are Triple extension and maximum bellows extension is 450mm/18" so far better for close up/macro work.
The 150mm and 210mm f9 G Clarons or Apo Ronars were sold in shutters and optimised for Infinity to close up work, Robert White (UK) and Badger Graphics (US) sold off Schneiders last stocks of G Clarons for just over £100 a few years ago.
While eulogising about the 203mm Ektar's there is a downside. the UK versions are mostly in a Kodak Epsilon shutter with a non standard flash sync, or a Prontor SVS, neither shutter has a preview lever so you have to set to T or B to focus. Only a few late ones were in a Synchro Compur #0 shutter with a preview lever. I'm lucky to have a very late production US version in the larger Graphex Compur #1 that was cheap (£30) as the shutter was sticky, it's now perfect :D
These are inexpensive lenses, I have a second in an Epsilon shutter that came with a complete Kodak Specialist 2 half plate camera outfit, including a case and Dalmeyer WA for £100, so don't use the current UK Ebay listings as a price guide as they are way over the top :D
You're welcome to come and try some lenses, I'm an hour north of Bristol.
Here's a Nikon brochure. Not sure of the date, because it doesn't include the 150 SW. The AM series description gives no definition of "macro" other than "1:1", and the M series simply says "versatile enough". My 150mm f5.6 Nikkor seems to work well in monochrome but I have no experience of macro in colour.
There's a useful table of image circles at the back.
  • Nikkor_LargeFormatLenses.pdf
The description for an App-Macro-Sironar (not a Nikkor, of course) suggests that they are designed so the the front and back cells may be exchanged when closer than I:3, to improve performance. With a symmetrical lens, this should give no advantage, but 1:3 might be a useful guideline.
May I ask if you are dissatisfied with the results you are getting? What do you need to improve?
It might be impolite and ungenerous to suggest it, but in my own case, Operator Error is the thing that needs to be fixed most often.
The Sironar lenses aren't a symmetrical design so that makes sense. Componon and Symmar lenses are symmetrical in fact their design is quite similar, it's just that the Componons are optimised for close distances.
It's often better to use a shorter FL macro lens that's why Nikon offer a 120mm as well as a 210mm, coverage increases with magnification, it's why I mounted a spare 135mm Componon in a shutter for close up work.
Yes, I've tried mounting a reversed enlarging lens, but adjusting the aperture ring was very fiddly.
We seem to be providing more information than Dom asked for, but not providing the definitive answer he wanted. Perhaps there is no answer.
I suspect that differences in skill may cause more differences than the optics of (relatively) modern lenses. And we haven't mentioned the quality of the tripod.
It may be a lot more information than I was asking for but I am always happy to learn some new interesting things!
the Nikon brochures are annoyingly lacking on any information about the specific lenses. I presume if you ever get one new it would come with a lot of information in the box but it is very unlikely to have them hanging around anymore I'm sure. The reason I'm asking is not that I'm seeing issues with my photos (I am actually still blown away with every LF shot I do compared with the smaller formats) but purely out of curiosity as I couldn't find any information with some google searches online. Currently, I have been lucky enough to find a well priced Technikarden, so plenty of bellows extension there, and have been using either a 210 or 150 W lens for any semi-macro stuff I do. I have seen no issues with the images at all, but again I have nothing to compare it against as I've never used a macro lens on an LF camera before.
That's annoying about the UK Ektars, I'll be in Japan later this year so I may be able to find one there in an old store. Who knows but ill keep my eyes peeled as people seem to love it.
I've seen that with the Nikkor macro lenses (the symmetrical design) and it is what actually got me thinking in the first place because obviously they wouldn't design lenses differently if there wasn't an advantage I just wonder where that cross over point lies. I wonder how those 1:1 macro lenses operate as general use lenses...
What's this about mounting reverse enlarger lenses? I have not heard anything about that before.
In an earlier post, Ian mentions Schneider mounting Componon lenses in a shutter.
Enlarging lenses are designed to have very high resolution, minimum aberration and flat fields. As their design is not constrained by having to focus at infinity, they can make excellent lenses for close-up work.
On the enlarger, their subject is the negative and their ground glass is the paper. They are designed to work this way round, with a short distance to the subject and a longer distance to the image. When we are approaching macro conditions, it's considered by many photographers that mounting the lens backwards gives an advantage.
De Vere, among others, made a device to replace the neg carrier with a film holder so that the enlarger could be used as a copy-stand. (Effectively, a specialist monorail macro-camera.)
The lens can be mounted in a shutter or directly on a lens board, using your trusty bowler hat for timing the exposure. There are, or were, adaptors for this. As I mentioned, it can be a bit fiddly to operate.
In the days when everybody had an enlarger, this was probably a good saving over buying a specialist lens for occasional macro shots. If you have one, give it a go.
Other members will certainly be able to tell you more.
I've never hears of reverse mounting enlarger lenses although it might make sense with older 4 element Tessar designs, the Componon's are symmetrical so it's not needed. It was common practice to reverse plasmats (fast 35mm standard lenses) for macro work with bellows and there's definitely an improvement in quality but a good enlarger lens is better still.
Using any LF lens outside it's design parameters for macro work will give less that optimal results compared to a lens optimised for that focus range. The main issue is field flatness, enlarger and process lenses are flat field designs, one can think of a process lens as having much better overall optimisation but the price is reduced max aperture usually f9, almost all are APO lenses.
It's quite easy to switch the lens cells of a 203mm Ektar into a modern shutter and recalibrate the apertures. I have one I bought in a jammed Prontor SVS.
Another simple and cheap way to go is find a 135mm f4.7 Xenar ad a 135mm Componon and switch the cells, the aperture scale is then correct and you have a Macro lens identical to those Schneider sold for some years, I've seen these shuttered Componon's marked Sinar as well as Linhof.
I have a Nikon-made reversing ring for enlarger lenses, so it's not quite unheard of. It came without instructions.
We still haven't decided when close-up morphs into macro and (presumably) into micro. There might not be a definable boundary and it's a matter of approach and purpose. With flat subjects, we might simply call it copying.
Sounds like something I could have fun trying that's for sure. It should be easy to fix onto a camera even without a specialist reversing ring. I love finding out about all these new things.
