Ordered my first 5x4 camera
RobMac
After discussing options with a few people, it became clear that it is a minefield buying an old, used 5x4 camera, with the likelihood of it needing some attention. Now, I know myself, and I know that I am useless at fixing things, so, there are only two possibilities: buy a used one from a reputable dealer with a guarantee of six months or more, at a price to match, or buy new from Intrepid, who are there for backup, advice, and a genuine guarantee.
So I placed an order - it will take three weeks - for the new Intrepid limited edition, black 5x4.
There. It's done!
Read all about it here, with pictures: https://intrepidcamera.co.uk/products/black-edition-4x5
This is an upgrade on their MK4 model. If interested, I was told over the phone that there are only seven left, now six, should you want one.
So, I also ordered four Toyo film holders from Japan, due also to arrive in three weeks' time.
The only problem is I am now skint, and can't afford a lens. But, there is no hurry, as I want to wait to get a good-condition Kodak Ektar 203mm with a good shutter. Plus, travel is severely restricted at the moment, and it might be a few months before I can get to some of the areas I have in mind.
You guys are dangerous! :mad::cool: But thanks to all those who gave advice...I think ;)
Why? You'll get better results with a more modern lens. Can I suggest something like the Nikkor 180mm f/5.6 with a Copal shutter?
I do have one of these and it is a beauty.
The Kodak would need a non-standard lens board hole, which would mean sourcing an un-drilled board and drilling yourself.
I know nothing other than what I'm told here, and the Kodak Ektar came highly recommended by two members. Now I'll look into the Nikkor, which I can't afford either right now. Thanks, Joanna.
The Kodak will not give you the same clarity as the Nikon or other, more modern, multi-coated lens.
I have to disagree. I have a modern f5.6 210mm Apo Symmar, and an old 203mm f9 Kodak Ektar. On numerous occasions I have taken the same picture with both to see if there is a difference. But when I compare prints there is no difference.
There are differences of course. The Apo Symmar throws a brighter image on the ground-glass. And it is much heavier.
May I suggest a Caltar II-E (or Rodenstock equivalent) 210/6.8? Absolutely great lens that can be had for little money.
The Intrepid requires Copal-style lens. I don't know if there are other types, but thought I should mention it.
Believe me Rob, the older lens render in a different way to the super coated modern versions. I prefer the look of my older lens to them, sharpness and contrast is not the be all and end all, art goes deeper than that, take the Pinhole camera with no lens, even the Holga lens, taste differs, for me my old Heliar lens are simply superb optics and so will be the Kodak Ektar you have choosen
Oh, I agree, Martin. I might be new to the 5x4, but not to photography. I love using old Leitz lenses on my Monochrom. The subtleties outdo modern sharper, more contrasted lenses.
With respect Rob you seem to be slightly confused here. The Intrepid requires a Linhof/Technika style (size) lens board which if memory serves is 99mm x 96mm (anyone- please correct if I've got that slightly wrong). On this lens board, with a suitably size hole hole, you will be able to mount most LF lenses in the range of 75 - 30mm as Intrepid state on their web site. Certain lenses will be physically too big to fit but I think you're hardly likely to come across one of those at this stage.
Depending on the lens you finally decide on will determine which lens board c/w hole you require and any member here can advise you on that. Intrepid sell high quality lens boards of the appropriate size although you may pick one up cheaper elsewhere.
Hope this helps. :)
OK, Keith, but this is on their website:
"Large format lenses tend to come mounted on a lens board and our cameras are compatible with any Copal style shutter."
But I would not be surprised if I am indeed confused. I'm trying to absorb a lot of info at once.
I haven't seen this on the site Rob but it is rather a silly statement. Most lens are sold without a lens board unless the seller is making it part of the sale. The beauty of LF lenses is that given a suitable size mounting hole they can be fitted to almost any make/size of lens board. The 'our cameras are compatible with any Copal style shutter' is also a bit nonsensical. The camera doesn't give a damn what shutter is used as long as the lens/shutter combination fits on the lens board, in fact I use some lenses with no shutter! ;)
I've seen a black Intrepid and it is very handsome. Too bad, I already have more cameras than any sane person needs.
It takes a Linhof sized lensboard onto which any lens can be attached, certainly up to a Copal 3. It all depends on the size of the hole.
Smaller fixed cameras and lenses have their mounts decided by their makers so that you are largely confined to putting Nikon lenses on Nikon camera bodies. (This is not altogether true, as you will know, but it serves as an example.)
The lensboard is an intermediary between the camera body and the lens. You could put a milk bottle on a Sinar if you wanted to. Or you could put a Cooke Triple Convertible on a shoe box.
The front part of the lens screws into the shutter and the shutter is fixed through the lensboard with a threaded collar and the rear part of the lens is then screwed into the back of the shutter. Copal is merely the most common shutter these days but there are others. Compur shutters are much the same bulk and operate in a very similar way
This assumes that you are using a shutter at all. It's not essential, but not having one limits you to longer exposures, using your top hat (if you're a gent) or your bowler (if you're not), to time the exposure.
There is a little tool you can buy to fit the different sizes of locking ring. More expense!
If you are only slightly handy, you can improvise a lensboard out of almost anything flat and thin.
Only time will tell you if you like the "look" of certain lenses. 180mm might be a good start for the "slightly longer" look. I suspect that lens advertisers try to define wide-angle lenses as landscape lenses to make us buy another one. They do let you stand a bit closer.
The important thing when buying a lens is that it has the fixing ring. Lensboards are readily available from China, and on Ebay.
Keith, the quotation comes from their FAQ's. It did confuse me.
Thanks, Dave. That helped.
So, Linhof board with Copal hole (1, 2, or 3) will fit most lenses. Intrepid sell their own boards if needed. What size hole would the Ektar 203mm require?
Like Alan I have to disagree, you need to see and try a 203mm f7.7 Ektar they are superb lenses, I've been using one with my light weight LF kit fora few years now, they'll out perform a 210mm Nikkor W or Symmar S etc for close up work, it's an inherent feature of the Dialyte design and they are optimised for 1:1 to Infinity.
In terms of clarity post WWII LF lenses seem to have been far better coated than some early coated 35mm camera lenses particularly wide angles. In practice I've never had an issue with flare or a contrast drop using coated LF lens or MC LF lenses, in fact my CZJ T coated 150mm f4.5 Tessar, and a coated 75mm f8 Super Angulon (on a 6x17camer) both performed perfectly shooting into the sun where as the MC zoom on my DSLR was useless the flare was horrific.
Uncoated lenses are quite different and you immediately see a difference particularly in micro contrast in highlights and shadows.
There's mention of the 210mm f6.8 Geronar (a Cooke triplet), also once sold as a Caltar-II E by Calumet, these were budget lenses excellent for Portraits at wider apertures but very sharp when stopped down to f22 - much smaller than a Nikkor W or Symmar S but in a Compur/Copal #0 sixed shutter.
Rob, the Interpid data is misleading as ait's more normal to say Compur/Copal #00 (avoid), #0, #1 or #3 sized shutter, there is a rare Compur #2 shutter. In around 1929 Compur moved from Dialset shutters to the modern rim-set style, their sizes became the defacto European standard later followed by the Japanese Seiko. Copal etc.
So Compur. Compound, Prontor, Epsilon, Copal, Seiko shutters are standardised fit and those of the same size have the same mounting thread for . Other shutters like Trikon, Ibsor, AGI, Pronto, Vario follow the same standards. American lens are quite different and there's no standardisation between makes you just file a board out to fit :D
Compur and Compound both made by Deckel originally may also come with a flange, this is more common with larger lenses often fitted to wood/brass cameras, these were probably an option but I have some like this.
That would depend on the shutter rather than the lens.
Copal sizes are listed as :
  • Copal #0 - 34.6 mm.
  • Copal #1 - 41.6 mm.
  • Copal #3 – 65 mm.
  • Copal #3s - 64.5 mm
I found references for hole size for a couple of possible (non-Copal) shutters that stated 32mm, which makes it smaller than the Copal #0. That would mean hoping it was light-tight in a loose fit or drilling a hole yourself.
My 203mm Kodak Ektar in Prontor-SVS shutter needs an accurate 32mm diameter hole in the lens board, or an approximate 35mm hole if you want the locking ring flange to go inside the hole.
