Keith,
Not even the midwife can separate a true-born Yorkshireman from his cap.
My 203mm Kodak Ektar in Prontor-SVS shutter needs an accurate 32mm diameter hole in the lens board, or an approximate 35mm hole if you want the locking ring flange to go inside the hole.
For the Intrepid, a rear element larger than about 84mm diameter would not go through the hole in the front standard -- but that is very big (my biggest, a 240mm Symmar, has a rear element housing just over 60mm in diameter).Certain lenses will be physically too big to fit but I think you're hardly likely to come across one of those at this stage.
Too bad, I already have more cameras than any sane person needs.
