Ordered my first 5x4 camera
Keith,
Not even the midwife can separate a true-born Yorkshireman from his cap.
Some information on Compur and other shutters.
This is the current sizes (rimset Compurshutters), case sizes for other makes and versions may differ slightly but tube lengths and thread sizes remain standard. But the sizes match the Copal sizes Joanne posted.
The earlier Dial-set Compurs.
One reason Compur introduced the new standards was because of the number of variations of the dial-set shutters making them costly to manufacture.
Keith,
That's very true David, from the moment of birth the whippet would be on guard with bared teeth to prevent such a travesty. Some say that it's the whippet that would sever the cord!
My 203mm Kodak Ektar in Prontor-SVS shutter needs an accurate 32mm diameter hole in the lens board, or an approximate 35mm hole if you want the locking ring flange to go inside the hole.
So, does that mean it would not fit the standard-sized Copal holes, or am I still missing something?
Sorry for the confusion Rob. I think the standard way to go would be with a 34.6mm diameter hole. The inner part of the locking ring then fits inside the hole and the locking ring fits flush and tight against the back of the lend board. But this doesn't leave much space to get a lens wrench in to tighten the locking ring. So with my home-made lens board I prefer to go for the 32mm hole which created space for the wrench, and works just as well in practice.
You will appreciate that neither of these holes needs a nice Torres-style decorative rosette surrounding it!
Though they would look better with one!
I think I understand your post. I need to get my hands on stuff, and play with it.
Yes, a good deal will become much clearer when you have things in your hands.
Text books can be very confusing, because they tell you how to solve problems that you don't know how to suffer from yet.
Rob, apologies for the confusion. The "official" hole size is 34.6mm. This is the diameter of the hole in my Kodak Specialist lens board. So probably best to go for this size. But a 32mm hole also works, and has the advantage explained above.
Certain lenses will be physically too big to fit but I think you're hardly likely to come across one of those at this stage.
For the Intrepid, a rear element larger than about 84mm diameter would not go through the hole in the front standard -- but that is very big (my biggest, a 240mm Symmar, has a rear element housing just over 60mm in diameter).
@RobMac
The limiting factor for any lens going on an Intrepid 5x4 is the size of the rear element and the weight of the lens. As others have already said, the type of shutter doesn't matter. That said, however, I'm pretty sure a Copal 3 shutter will consume most, if not all and then some, of a Technika-style lensboard. Therefore, you would probably have to have the camera in hand to see if anything about the front standard would get in the way of actually putting a Copal 3 shuttered lens on the camera. I probably wouldn't worry too much about Copal 3 because most lenses requiring this size shutter would be too heavy for the Intrepid.
Gobbledegook is my favourite language. I make no claim to sanity, but my invisible unicorn is perfectly normal.
The way LF lenses are configured can be quite confusing for a beginner. I know because I was one about 4 years ago! PM me if you want to chat to someone about it.
