You might think about making a large extension back that you hook up to an existing camera, that way you use the existing focussing mechanism etc,
I had actually considered this, but I guess I feel that if I'm going to go to all this effort, I'd rather make a complete camera. This also makes the build last longer which is a factor, as I want this to be quite a long term project.
I can see a chicken-and-egg situation here. If you are designing and building a camera from scratch - let's say a 5x4 camera- then it makes sense to first buy a film holder. The camera back is then designed and built round it. But Jonathan is designing and building his own film holder. and won't know if it works until he has tried it out in a camera, which he may need to modify in the light of things like light leaks..... He certainly has a few interesting problems to solve.
Jonathan, what are you thinking of making the film holders out of?
I see what you're saying. I think what I'll do is make the film holder first, then I can at least test the light sealing on this by simply loading it and taking it outside in the sun (with the dark slide in place, obviously
) for a few tens of minutes and the developing the frame. I may try and buy a single sheet of film from someone so increase the ISO from that of the paper I want to shoot, in order to make any leaks more obvious. Once the holder is light tight, I at least know then at if there are any leaks after building the camera, the leaks are likely not coming from the holder itself.
As for the holder itself, I'm not yet sure. I have a CAD drawing of what I think might be a good build, but as for materials, I am not sure. I'm reluctant to use metal due to weight - I may as well save weight where it's sensible to do so - so that leaves wood or black acrylic. The Chroma cameras have shown that coloured acrylic can be light proof, so this is an option.
This might be of interest,
www.secondhanddarkroom.co.uk
No shutter, but many a good picture has been taken with a bowler hat.
And yes, coplanar is exactly the word. Parallel too, but I don't think you'm make a mistake there.
Some designs simply remove the ground glass frame and replace it with the film holder. That design would eliminate all the springs and suchlike.
That is very much of interest! Shame it's not in a shutter, but as you quite rightly say, this is not a problem, especially with such low ISO paper. Am I correct in thinking that the f/5.6 part of the lens description is a typo, and that it's actually f/6.8?
Can the cells of lenses mounted in just aperture units be taken apart and put in copal shutters if required?
Thtah's exactly what I did with my home made 6x7 field camera, essentially a Grraflok back but the focus screen/fresnel frame is just removed abd the roll film back fitted. I should add a hinge so I just unlock the sliders and swing the fram e sideways.
When it comes to lenses as there's no enlarging the quality of a Rapid Rectilinear would be more than enough, I have the 12"x10" contact prints of my Grandparents 1910 wedding and they would have been shot using an RR lens, the quality is superb.
Ooo, a hinged GG frame, I like this idea. I may try and incorporate this somehow....
I confess I'm not fully up to speed with the technology incorporated in lenses of this era... what is rapid rectilinear? I am aware of what each word means - but perhaps not in combination and precisely in this particular context.
