11x14 lenses
Just in case anyone is wondering, I plan on documenting this as I go and I'll probably start a new thread showing the progress. If anyone is interested nearer the time, I'd be more than happy to share the design also.
Thank you for sharing a progress report. I, for one, would love to get your plans when done. Who knows? You may motivate me to build a 14x11 for myself! ;)
If you are making a one-off camera for your own use, there's no need to duplicate conventional commercial film holders. This opens all sorts of possibilities. The only cast iron rule is the position of the film plane.
Looking forward to the documentation.
This was essentially my thinking. Goodness knows if it'll work, but a good part of the fun is trying :)
When you say the position of the film plane, I assume you mean that it aligns co-planar with where the GG was when focusing/composing - If so, this I did know... Unless there is something I'm missing?!
There is an excellent website on home made LF cameras, essentially it''s links to many peoples websites describing their home built cameras. Go to the Camera Builders link.
Early wet plate holders were quite simple but light tight, that might be a way to go.
Thanks for the link Ian, much appreciated, I'll definitely give this a look.
No probs! As said, it'll just be the result of my opinion on the various design aspects, so people may look at it and laugh! That being said, if it can be of any use to anyone, I'd be happy with that :)
You might think about making a large extension back that you hook up to an existing camera, that way you use the existing focussing mechanism etc,
I can see a chicken-and-egg situation here. If you are designing and building a camera from scratch - let's say a 5x4 camera- then it makes sense to first buy a film holder. The camera back is then designed and built round it. But Jonathan is designing and building his own film holder. and won't know if it works until he has tried it out in a camera, which he may need to modify in the light of things like light leaks..... He certainly has a few interesting problems to solve.
Jonathan, what are you thinking of making the film holders out of?
This might be of interest,
No shutter, but many a good picture has been taken with a bowler hat.
And yes, coplanar is exactly the word. Parallel too, but I don't think you'm make a mistake there.
Some designs simply remove the ground glass frame and replace it with the film holder. That design would eliminate all the springs and suchlike.
Thtah's exactly what I did with my home made 6x7 field camera, essentially a Grraflok back but the focus screen/fresnel frame is just removed abd the roll film back fitted. I should add a hinge so I just unlock the sliders and swing the fram e sideways.
When it comes to lenses as there's no enlarging the quality of a Rapid Rectilinear would be more than enough, I have the 12"x10" contact prints of my Grandparents 1910 wedding and they would have been shot using an RR lens, the quality is superb.
I had actually considered this, but I guess I feel that if I'm going to go to all this effort, I'd rather make a complete camera. This also makes the build last longer which is a factor, as I want this to be quite a long term project.
I see what you're saying. I think what I'll do is make the film holder first, then I can at least test the light sealing on this by simply loading it and taking it outside in the sun (with the dark slide in place, obviously :D) for a few tens of minutes and the developing the frame. I may try and buy a single sheet of film from someone so increase the ISO from that of the paper I want to shoot, in order to make any leaks more obvious. Once the holder is light tight, I at least know then at if there are any leaks after building the camera, the leaks are likely not coming from the holder itself.
As for the holder itself, I'm not yet sure. I have a CAD drawing of what I think might be a good build, but as for materials, I am not sure. I'm reluctant to use metal due to weight - I may as well save weight where it's sensible to do so - so that leaves wood or black acrylic. The Chroma cameras have shown that coloured acrylic can be light proof, so this is an option.
That is very much of interest! Shame it's not in a shutter, but as you quite rightly say, this is not a problem, especially with such low ISO paper. Am I correct in thinking that the f/5.6 part of the lens description is a typo, and that it's actually f/6.8?
Can the cells of lenses mounted in just aperture units be taken apart and put in copal shutters if required?
Ooo, a hinged GG frame, I like this idea. I may try and incorporate this somehow.... :)
I confess I'm not fully up to speed with the technology incorporated in lenses of this era... what is rapid rectilinear? I am aware of what each word means - but perhaps not in combination and precisely in this particular context.
All field cameras that took book form plate holdesr use a hinged focus screen frame, the spring back pre-dominated originally in the US from around 1900 and unlike the UK and Continental Europe they standardised to a large extent early on the dimensions of the modern plate/film holder sizes we have today.
Rapid Rectilinear lenses were the 1866 Dallmeyer symmetrical 4 elements in two groups break through replacing earlier Petzval lenses that suffered from severe Radial distortion at wider apertures. They were the main lenses in use until the introduction of the Cooke Triplet followed by Protars, Dagors and finally Tessar lenses, they remained in production as good budget lenses until after WWII but weren't available separately and by then were only fixed lenses.
Petzval's remained in production for a few more years as Portrait lenses where people liked the swirly out of focus effects, eventually they were largely replaced by TTH Cooke Triplets with built in soft focus control.
Back to RR lenses they are very capable, they won't be quite as sharp as modern Plasmats at wider apertures but you would only see this if enlarging. I rember the quality of the images made by Victorian photographers using RR lenses I saw first at "The Art of Photography" 1989, the major 150 years of photography exhibition shown in the US - Houston, UK - London at the Royal Academy of Arts, and Australia - Canberra.
To be honest, I hadn't spotted that and the image they offer is a bit blurred, but I think you're right.
Unlikely to be critical if you are also considering f9 lenses.
One thing I should mention is that the figures for image circle can be taken with a pinch of salt. A small pinch, perhaps. The world does not suddenly come to an end at the edge of the prescribed circle, but rather, this is the point at which it no longer meets the the criteria set down by the manufacturer.
Quite often, there's no significant detail in the corners anyway – for example a cloudless sky or a shallow-focus portrait – and a bit of liberty may be taken. You probably know this already.
As we've introduced corners, you might also start looking for a large Fresnel sheet – the kind used for reading or on overhead projectors, perhaps – to help with viewing. If you read opinions on various other LF Fora, you might imagine that a Fresnel screen is made by a mystic process, probably involving the blood of virgins and a full moon. It's only a condenser lens. Almost any kind will be better than nothing and they can be bought for substantially less than a King's ransom. Naturally, some are better than others.
Before Ian gives a proper explanation, rectilinear means no distortion and rapid means fast for the day.
PS: Oops, I forgot to press "Post" Ian has answered in much more detail than I could.
Some early lenses covered huge formats. I have a couple from ~1860 which are reputed to cover 22" x 18"- if the stop is moved closer to the lens itself that is (not that expensive either especially compared with modern large coverage lenses). But the result is an 'old' look and of course the widest aperture is very slow (f/11-16). Many graphic and aerial lenses will offer good coverage stopped down too and since your end result is unlikely to be enlarged they should be quite reasonable to use.The only thing to be really aware of with old lenses is that they are uncoated and will need a good hood making (of a Haselbad bellows hood modifying - they are cheap now) to minimise contrast drop.
If you are making the camera yourself you might consider a Packard type shutter (used copies are reasonable enough) fitted inside the camera. Rapid Rectilinear lenses (almost certainly wrongly credited to Dallmeyer) will work well but to get one with good coverage may be getting costlier - Wray, Beck, Ross, Dallmeyer and numerous others made them - no shutters though. Its worth looking through the Lens Made Mecum to get an idea of what was produced, then cross reference with what's on offer and prices. I have a ~1880 12" x 10" camera which I have to say was cheap enough, but find a 10" x 8" far more viable myself although the size is not massively different.
I accidentally found this which may be of some interest.
