Shutters and aperteurs
I've written out a workflow which I will follow then no doubt I'll need to add the bits that I've forgotten. I've always wanted to have a large format camera since I was young but of course they were always out of my budget and I was convinced that it would all be too difficult - I'm aout to find out if I was correct.
Okay - shooting large format is no more difficult than shooting 35mm.
I can hear the pitchforks being sharpened and the torches being lit ... but bear with me.
Making reasonably exposed negatives in the same ratio of success to failure you get with 35mm is just as easy with large format. However the difference is you want a better hit rate when your materials cost a truck load more! So of course large format is more difficult!
You have to realise that you are the same photographer whatever format you use! So if you expect failure at the same rate as 35mm - you won't be disappointed :)
Because you have to think more, you get a better hit rate with LF, the thought of the cost per image helps with double-checking everything :D
It actually improves your hit rate with smaller formats as well.
I’m inclined to believe that I get a better hit rate with LF. There are however, two kinds of hit. Firstly, getting a well-exposed, decently sharp, appropriately developed negative is always an ambition. Quite often fulfilled because of the constant pressure to check. [Digital photographers may find this very strange.]
The second kind is getting something worth keeping. Am I alone in thinking I got better 35mm pictures on the last few frames of a roll, which mimics the condition of LF? This may all be self-deception, of course.
Well yesterday was a bit of a trying day - first off my glasses frames snapped so that was the first struggle to overcome, lots of glue and sweary words so maybe that got the sweary words out of my system to start with. then I tried to do two things at once - not a great idea but there was method in my madness. I have some old fomapan 100 4x5 film so I wanted to see if it would work as normal or not so this was really just experimenting as I don't know if the camera will have any light leaks or any other issues. So my theory was to shoot the same but new film in my old Lubitel166. Well I chose a little bird bath as the subject since it is a nice 18%grey it saved any hassle with thinking about zones etc but I did look at different areas just for practice, got the best focus I could without using a dark cloth but I will use one in future particularly with this F8 lens being the only one working until my shutter arrives back and managed to remember to close things down before removing the dark slide and taking the shot.s I only had one problem and that was getting one of the dark slides back in after taking the photo - it seemed to jam and I wondered if I hadn't got the film in correctly and it had all bucked up - I hadn't and it hadn't so it was just a sticking dark slide (not sure what to do about that) took the same shots with the Lubitel then when I went into the house I thought I musrt remember to wind the film on in the Lubitel before leaving it for later- at that point I realised that shooting digital does something to your head because I hadn't wound the film between taking shots so I went out and did them again. All in all I found the 4x5 easier to remember what order to do things in than the Lubitel but it was supposed to be a time for finding out what not to do anyway. I also took the Lubitel for a trip out for the day (it was our wedding anniversary so I couldn't just spend the day playing) and I also learned that seeing those little numbers on the film sin't that easy so wound past one section by accident. Anyway I did manage to get the film into the holders, take a coouple of shots, get the film out of the holders and into the tank successfully well at least I think I did. Today I'll do the developing and see just how badly I did.
I used to like the smell of carbon tet. I did work really well.
Carbon Tet - possibly tall - tale:
My first boss, in the University of Cambridge Chemistry labs, early 1970s, told me how he once gallantly offered to remove a stain from a lady staff member's skirt. Carbon tet worked a treat of course, but also dissolved her nylon stockings underneath in the process...
I still had a bottle of Dabitoff for many years, but it eventually evaporated... wonderful stuff
For sticky dark slides I take em out and use household spray polish on them ... works wonders.
I get frustrated with 35mm as there are just too dang many images on a roll! Luckily my Nikon F4s has motor drive faster than five frames per second ... so ... er ... job sorted :)
Seriously, my RB67 with its ten shots per roll is far more friendly re impatience to see the results ... shame it's heaver than my 5x4 camera!
Well I was in for a bit of a dissappointment - the film from the Lubitel came out ok but the film from the 4x5 didn't I've either got a light leak on the camera or the film has been fogged before I got it.
Now how do I work out which? I can try the light inside the camera tonight to see if there's anything obvious. I'm going with camera or fim issue because the two shots came out the same with the negative dark down one side so unless the dark slide has the same probem on both sides it has to be one of the other two. the other half of the negative doesn't look too bad.
I guess I could develop a sheet or two unexposed to see if it is the film - wish I'd thought of that before trying it really but this is a learning exercise
It can be very difficult to find some light leaks, Some years ago I borrowed an MPP MicroPress to compare it to a Pacemaker Speed graphic, (many common parts), the owner asked me if I could find & fix the intermittent light leak before returning it. I tried a torch in the darkroom and couldn't find it, In the end I put a flashgun inside the camera, sealing its cord though a lens board, I then found it was where the bellows were attached to the rear of the camera. I was then able to fix the issue.
Definitely develop a sheet of unexposed film first in case it is fogged.
Well I think that is fairly conclusive - it's the camera!Photo671290577048-inner-125-15-741-15-125-707-741-617.JPGPhoto671290597942-inner-309-514-698-514-309-855-698-855.JPG
I'm guessing it is the felt around the dark slide face but I'll get a light in there tonight to see what might be causing the problem. I could of course just await the delivery of my intrepid but that's going to be at least another two weeks possibly four and I need something to play with
I've had an idea - I have a little pi controled camera that I set up for the "My nature cam" project - it is infrared sensitive as well for dark work I can put that inside the camulet first looking at one end then at the other I should be able to see any issues I think - I'll give it a go. If that doesnt work I've got radio controlled flash units I can try - thanks for the idea Ian
Well the little camera showed nothing so I'll have to wait until it is dark and have a go with the flash - it can't be impossible to find. At least I know what it isn't
I use a super bright LED torch and do it in a blacked out room - takes a while for your eyes to get accustomed :)
Well I found one light leak that was fairly obvious - I had to use a bit of foam to try to make a light seal for my lens board because I dont have the Camulet lens boards that have a little lip that fits into a groove - the foam had shrunk slightly since I had fitted it and left a tiny gap - Now I'm wondering if I should spend more money to try to get the correct lens board for the camulet or continue as I am at the moment - this thing is so big and heavy that I can't see it getting used much once the intrepid arrives. Anyway I have replaced that bit of foam and might have another go to see if it has resolved the issue or if there's another hole somewhere that I haven't found.
Well I got my shutter back fully serviced and it is operational and I'm delighted now sadly I have to wait until my new lens board arrives as this lens needs a size 1 board. Can't believe the prices people are asking on Evilbay so back to Intrepid and a new board for £15 thank you very much. I still think I got a bargain even after paying for the service of the shutter. :0) And I see I've been promoted from being a new member to being a member - I must be getting old - I know I'm getting old
I've got one ordered now but Mike Walkers site? I don't know of this
You've never heard of Mike Walker? Wow, you are new to LF ;)
Go there - be amazed - the great LF camera manufacturer in the UK.
Thank you - another site to peruse - still not beating intrepid's lens board price though. I actually like supporting small firms so I'm happy enough supporting Intrepid. As to being new to LF that would be very new - I had no intentions of going LF until I got the idea of adapting an old camera to give me lens movements for my digital camera but I've fallen for it now and have started reminiscing about printing my own in a darkroom again after a gap of 50 or so years. I'm really enjoying going back to film photography and have been donated the family's collection of film cameras which goes back to my Grandmother's kodak brownie 3 - sadly can't get 124 film anymore but I might try putting some 120 through it. Even have my dad's Bolex cine camera now though I can't see me using it really but it is a beautiful piece of kit
