As they rais the resolution in each latest camera, isn't each sensor smaller to absorb less light? They say they're combining cells to add more light but why not just use less cells but larger ones?
It seems like they're selling more resolution which sounds very familiar to what the camera industry has been doing for the last twenty years.
Not sure why this question is in this thread but ...
A "sensor" is an array of light sensing elements. Today, digital sensors largely fit in several general categories: FX, DX, 4/3, Medium Format (and whatever digital point and shoots use). For a given size sensor, you get higher resolution by cramming more light sensing elements into the same space. A "light sensing element" is a special kind of light sensitive transistor that generates electrical noise, particularly as temperature goes up. So we can increase resolution (more pixels) but almost always at the cost of creating more noise. Camera manufacturers address this by taking the "raw" image off the sensor and using digital signal processing techniques to reduce noise and other capture artefacts.
Light sensitivity is largely a function of two things: Those "light sensing elements" and the amplification systems they are connected to, to produce a final image. The amplifiers themselves are also a source of noise, BTW.
"Resolution" shows up in two ways, in both film and digital systems. There is
optical resolution - the resolving power of the lenses - and there is
capture resolution which is the resolving power of either the film/developer combo or the digital sensor. Optical resolution is a function of the lens design and bounded by diffraction effects. No matter how sharp your lens is, if you stop it down far enough, it's going to diffract and adversely affect image sharpness. This is true for both film- and digital cameras, but digital systems inherently diffract sooner (at a larger opening) than film. Why? Because digital systems actually have two sets of lenses - the one you are shooting through and
the effective "lens" each sensing pixel has. Where a film camera will diffract at, say, f/16, diffraction in digital systems can be seen as early as f/5.6. These days, sensor design and in camera image processing is used to try and minimize this, but it's still a thing for digital cameras.
P.S. Fun Fact: The net resolution of a camera is a product of it's optical resolution and its capture resolution. For film cameras, the limiting factor is typically the optical resolution, because film can resolve far more than the optics can. So, in film cameras, just how much you need from your optical system is directly a product of how big the negative is. Why? Because smaller negs have to be magnified more to get a given print size.
The final resolution of a print it roughly the resolution on the negative divided by the magnification required to make a given print (assuming no significant impairment of your enlarging process). So, for example, if you magnify a 35mm negative 10x and your lens can resolve 50 line pairs/millimeter, the final print will have 50/10 or 5 lp/mm of final resolution. That's why lenses for smaller format film cameras actually have to have
higher resolving power than lenses for larger formats - the smaller negs will require greater magnification. I was sort of shocked when I first discovered that my fancy Hasselblad and 5x4 lenses actually had less resolving power than my Nikon lenses did ... because they don't need it.
