The relatively low contrast of the wall is caused by the angle of the sunlight, not by development. If it had been taken a little earlier, the light would have just grazed the surface, revealing a great deal more of the inherent roughness. It might have been interesting to make a series of exposures as the sun progressed around.
Yes indeed. The grain is more like 35mm Tri-X, perhaps in Rodinal Curious. I’ve never seen micro reticulation. Can this be it?
This was one of my first tries at stand development using Ilford DD_X in a 1:9 solution.
I could have done so I'll go back and have another go and see how it turns out making sure nothing is adding sharpening. I know when I export to JPG there is a small amount of sharpening added but that should show in the flat scans too so it likely isn't that.Did you apply any sharpening? Some settings can exaggerate grain.
Well it turns out I was using Fomapan 200 not 100 (I knew I had 100 but it turns out that is for the half plate). So I definitely overexposed
As for the choice of stand development, honestly I was just trying something different to see how it worked.
gitbucket.tundraware.com
So much to learn. Thank you.
