Nikon 90mm sw 90mm 4.5
soupdragon
Hello.
I have a Nikon 90mm SW 4.5 lens.
It does not seem particularly sharp in contrast to the internet rumours or my experiences.
Perhaps I'm expecting too much however, my Rodenstock 180 5.8 is light years better regarding contrast/sharpness.
What I have noticed is that the Rodenstock lens has a shim/washer between the front element group and the shutter assembly whereas the Nikon lens does not.
My question is, is there something missing from the Nikon lens?
I read the 90mm 4.5 should be a very sharp lens, sadly, my copy is not.
I really need some help here. Am I missing a washer/shim?
Missing shims shouldn't lead to badly sharpness.
As an example Rodenstock added shims to this famous Repro Lenses called Ronar if the customer wanted a shutter instead of a lens barrel.
Barrel lenses without shims typically made their repro thing at 1:1 whereas shutter lenses are used as pictorial lenses ; with shims they give better performance at distances to infinity. That has been sad by Rodenstock..
I never have heard of Nikor lenses being not sharp.
To me there issomething wrong either with your lens, your lens mountig - or with your focusing praxis.
Wide angle lenses have great depth of field but less depth of focus which recommends exact focusing, especially concerning parallelity of the standards.
Do you have overall unsharpness or particular unsharpness, and with f-stops are given to your unsharp results?
Thanks for such a rapid response,
My Nikon 90 4.5 lens is not as sharp as my Rodenstock 180 5,6 or my Nikon 150 5,6 by a mile at any aperture.
What do you think the shim does or am I barking up the wrong tree regarding image sharpness?
I can post comparisons although I can't recall camera settings.
Hi, I have the Nikon 90mm f4.5 SW and I can't say I've noticed anything amiss.
The specs. show that the 90mm (600g) is 50% heavier than your 180mm (400g) and more than 2.5 times heavier than the 150mm (230g)
It's a huge hunk of glass is what I'm getting at, so could that indeed be a source of the quality discrepancy?
The spacing with wide angle lenses is very critical. There were issues with early post WWII 90mm f6.8 Angulons, some weren't sharp that lead to Linhof selecting lenses after testing batches, Sinar did the same. The issue wasn't Scneiders making, years later an Australian repair technician Dean Jones, who made Razzledog Polaroid conversion cameras, found that the Compur Rapid shutters used for the early 90mm Angulon had inconsistent tube lengths, sometimes too long. He machined a few shutter casings to the correct barrel length and turned unsharp Angulons into excellent performers.
My 90mm f6.8 Grandagon N has two shims. When wide angle lenses are made there's slight tolerance differences between front or rear cells, manufacturers match front and rear cells on an optical bench and may adjust the barrel length with shims, so if a shim is missing who knows.
As Reginald S says Apo Ronars are sometimes shimmed when in shutters, I bought a Copal 1 shutter with just one 240mm Apo Ronar cell (rear), for the shutter itself, the rear cell was shimmed. However with Process lenses shims can be used to optimise for use to Infinity.
There's a large CZJ Apo Tessar, might be the 900mm, that has a large almost small extension tube sized spacer that isused to change from use to Infinity as a taking lens, or 1:1 for repro work.
I have a 90mm 4.5 Nikkor and it performs well. I habitually use it at f22.
Shims are essentially corrective, so you shouldn’t need one if your lens is normal. Are the front and back cells screwed into the shutter properly? Does the shutter itself say something like: “Specially made for Nikon.”? If not, it‘s probably not the original shutter.
As Reginald S says, although wider angle lenses have more depth of field, they have much less depth of focus, so accurate focusing is more critical. (See how 35mm cameras use a fine thread to focus, not a rack and pinion.) Are your images unsharp in the wrong plane or are they unsharp overall? Surely, some part should be in focus? It’s possible that your focus technique needs revising. I hope you take this as well-intentioned advice and not an insult.
mm The spacing with wide angle lenses is very critical. There were issues with early post WWII 90mm f6.8 Angulons, some weren't sharp that lead to Linhof selecting lenses after testing batches, Sinar did the same. The issue wasn't Scneiders making, years later an Australian repair technician Dean Jones, who made Razzledog Polaroid conversion cameras, found that the Compur Rapid shutters used for the early 90mm Angulon had inconsistent tube lengths, sometimes too long. He machined a few shutter casings to the correct barrel length and turned unsharp Angulons into excellent performers.
I can't say this enough. it seems your knowledge of all things large format is unbounded.
Is it possible my 90mm f4.5 Nikkor needs shims to make it critically sharp. If that is the case, is there anywhere in the UK that has the requisite skills to tune this lens?
Insult??? no way. I need this input!
So, to clarify. You have a Nikon 90mm 4.5 and you get sharp images from it at infinity or beyond! I'm thrilled to hear that.
If you have ever taken the front element group off, does it have a shim/washer that would effectively increase the the gap between front and rear groups?
Sorry to be a pain but I need you to respond.
Does the shutter say Nikon on the side and possibly SW 90mm f4.5. The marking on my 240mm W in aCopal 3 are between the shutter release arm and preview lever.
The question is was the lens shimmed and they got lost when fitting or removing from a lens board, at some point. You would need someone with an optical bench to test the lens to check if shimming the rear cell improves sharpness.
There are occasional lenses that slip through QC, I was given a 150mm f4.5 Carl Zeiss Linhof Tessar a few years ago that is not sharp at any aperture or distance, now I also have an East German CZJ 150mm f4.5 Tessar that's excellent.
I have a couple of shims and they are 0.15mm & 0.60mm thick, they won't fit your shutter though.
If you have any Copal O shims I'll gladly take them off your hands.
For a Princely sum of course.
Do you know of anywhere in the uk that can calibrate a lens of this design?
If you click on the image you can see larger versions which do appear to be very sharp, as are all Alan's images.
I don't have spare shims.Off-hand I don't know who could sort your lens out. If you were closer I'd suggest letting me test the lens.
Here are some examples.
Ok, there are some colour balance issues but which do you feel is the sharpest?
These are 100% crops.
I wouldn't call the 180mm shot particularly sharp, there may be other issues at play here. I would have thought the first shot would not appear to be sharp on the focus screen.
I'm probably too far for you to pop over with the lens & camera, I'd test it on my own camera first.
You;re enlarging the 90mm image 2x to match the normal zoomed-in optical enlargement size of the 180mm. That's not a fair comparison to compare sharpness.
Where are you based.
Good point.
My problem is, all the Nikon 90mm shots are visibly (a lot) softer than either my 180 Rodenstock or my Nikon 150.
I don't think it's my technique either.
I use a sturdy geared head tripod, and a cable release.
The lenses are always stopped down to at least their recommended apertures.
I'm always on stable ground and I don't take the camera out when it's windy.
I don't know what else to do.
We can rule out vibration, because that would be more evident in the 180mm shot.
Perhaps you could try a cheap and cheerful test on the lens? A Post-it note or a chinagraph might be useful. These are to mark the zero-adjustment starting point.
Focus as well as you are able on some suitable well-lit high contrast subject, using a decent, carefully-adjusted loupe.
Unscrew the rear element by half a turn. Examine the ground glass and re-focus.
Another half turn… and so on.
The threads are sufficiently fine to replicate shimming and sufficiently well fitting not to droop.
Make notes each time, of course. If there is an improvement, keep testing until it gets worse again.
Obviously, you can refine this with smaller increments and if there is any improvement, you can finalise by taking actual images.
After that, there is no immutable law that the shims must be made from metal. You can easily cut one out of stiff card, or build up the required thickness with several sheets of paper.
Another, and more pessimistic explanation is that one or more of the elements has shifted. This almost certainly needs the help of a grown-up.
Added later. For more accurate focusing, you might try the parallax method. Replace the normal GG and Fresnel with clear glass. Make a cross on the centre on the lens side, with a fine black pen.
it might be convenient to apply a few strips of matte tape nearby to use for focus.
The method is that you look at the very small part of the image visible through the lens. You will not see the whole image. Now you move your head sideways, back and forth. The image will appear to move, relative to your black cross. When the image does not move, then the camera is focused on the same plane. Rather cumbersome-sounding, I know.
As you are taking no photographs, it does not matter if the clear glass is the same thickness as your normal screen, but if you are, then the surface should be in the same plane as the film surface in the dark slide. This will depend on the construction of the individual camera.
You reminded me when I replaced the lens board on a couple of my lenses, I had to be careful to make sure that both parts of the lenses were screwed down all the way tight to the boards.
