A tiny clarification, if I may, to Mr Klein’s remark on re-assembling his lens. The front and back cells are screwed into the body of the shutter, not into the lensboard. That’s held by a collar and is mechanically isolated from the lens cells.
With regard to the fresnel, we seem to be discussing (and are in danger of conflating) two things. Firstly, the position of the screen in the stack. Almost all cameras have the actual ground surface closest to the lens, and facing it, so no optical element intervenes between the rear element and the ground surface. Next, on the photographer‘s side, goes the actual fresnel screen, and on top of that, on the photograph’s side, a thin sheet of glass, because most fresnels are made of quite soft plastic, chosen for clarity and fidelity in moulding, not robustness. It needs protecting from the bottom edge of the loupe.
Secondly, the orientation of the fresnel itself. I’ve never come across any debate on which way a fresnel should face, as I’ve assumed that being so thin, it would make no difference; I may well be wrong. Where possible, I’ve placed it so that the grooves are protected by being inside the sandwich.
Some specific cameras are constructed differently, but we have a member who is infinitely better-informed than me.
