Nikon 90mm sw 90mm 4.5
Hello all.
As an impulse buy I bought a Schneider Super Angulon 90mm f5.6 XL110 degree lens.
Assuming my camera does not have a mechanical issue, would the above lens normally produce sharp images?
Thanks to anyone with any experience with Angulons.
It should be a superb lens.
I've just had a quick look and the rear element of the XL is 86mm and should just fit, into the 100x100mm opening of your Toyo. But I presume you've already checked this?
You may also be better off with a recessed lensboard at some point allowing more room for the bellows, if you don't already have one or if it doesn't already come with one.
Depending on how squashed up the bellows are, this can affect lens focus and lens movements.
Oh! bollox.
I forgot to check that.
I made a typo in my original post as it should have read 110 degrees as opposed to 100.
I think the 110 degree lens has a 96mm rear element diameter.
`"What have I done!"
Everything I've read says it should fit Toyo 45's but please measure the size of the opening on your front standard and let us know.
Was the Nikon on a flat or recessed lensboard?
The Nikon is on a flat board.
I can't tell if the Angulon will fit until it turns up. Part of the problem is the way the lens board is attached to the front standard. On the Toyo you have to fit the board into a clip at the base of the front standard the tilt it backwards.
The Nikon 90 clears the top of the recess by about 7mm so I don't think it will fit in the customary manner.
My guess is that I'll have to fit the board and front optical group first and then fit the rear group by removing the camera back and screwing it into the shutter.
The only thing I can think is to send the lens to Pierro Pozelli. He's got some quite impressive gear now so might be able to help.
