New toy.
soupdragon
This arrived today.
Schneider APO Symmar f5.6 240mm in Compur 3.
What an amazing edge to edge view on the ground glass!
I have not tested it yet so I have no idea what the general image quality will be like.
On the downside, it's a LOT bigger and heavier than I was expecting, I guess I should read the data sheets before I press the buy button.
Anybody here got or used one. I could use a reference frame.
If it's anything like my APO Symmar 150mm f/5.6, you will absolutely love it. The 150 is tack sharp and contrasty, so I'd expect yours would be the same.
I don't think you'll be disappointed! :)
Mine are Symmar-s, 240 and 300mm both f5.6 in prontor 3's and a 360 f6.8 in a compur 3.
If you're sticking to a field camera, I'm sure your 240mm will serve you very well and will prove to be a better option than the longer and even bigger and heavier focal lengths.
Enjoy! And I'm looking forward to seeing the results.
It appears I need to use a touch of rear extension to get focus at infinity.
I own a Toyo 45A and can use nearly the full range of movements with the 240mm, it's incredible.
That said, as always, the proof is in the pudding.
I'm hoping for better edge definition with colour film.
The lens on the right of your picture looks massive.
What is the 35mm equivalent of the 150mm?
I want one of those as well.
There are two ways to look at this - film dimension or angle of view.
FILM DIMENSION
A "normal" lens is nominally defined to be the diagonal length of the film format.
  • For 35mm this works out to be 43.27mm
  • For 5x4 this works out to be 162.64mm
  • So, the 35mm equivalent lens would be: (150mm / 162.64mm) * 43.27mm = 38.98mm
    But no one has 43.27mm normal lens on their Leica or Nikon. We pretty much settled on 50mm years ago so ...
  • 150mm / 162.64mm) * 50mm = 46mm
    IOW in 5x4, a 150mm is more-or-less the equivalent of a 50mm on a 35mm camera.
    But this is misleading, because the "normal is diagonal" this is very much just a nominal standard. This is a better way:
ANGLE OF VIEW
  • A 50mm f/2 Summicron has angle of view of 40 degrees horizontal, 27 degrees vertical on 35mm film
  • A 35mm f/2 Summicron ASPH has an angle of view that is 54 degrees horizontal, 38 degrees vertical on 35mm film
  • A 150mm f/5.6 APO Symmar is 54 degrees horizontal, 44 degrees vertical on 5x4 film
So, from this perspective, a 150mm lens of 5x4 film "sees" about what a 35mm lens sees on 35mm film which is, I think, a better way to find equivalency.
Very nice, and in a (relatively) late production No. 3 Compur with a nominal top speed of 1/250. And should you ever want to do 8 X 10 it will provide you with a moderately wide angle lens.
David
It really surprises me that a non-tele 240mm won't focus at infinity just with normal bellows extension on your Toyo A...
I'll be honest here, I only got the lens on the 24th Sept so have only looked at stuff in my back garden whilst being stood in the kitchen.
I have no idea what infinity is but the end of my property is probably not infinity.
David
How can you tell it's a late version?
I have to admit the extra stop on shutter speed is a bonus over the copal 3.
The last version of the No. 3 Compur increased the top speed from 1/200 to 1/250. This may have been the result of a new sort of main spring, not sure of that. Also the last version added a shutter speed scale to the front of the shutter. The diaphragm on your shutter should have click stops in steps of 1/3 of a stop.
The No. 3 Compur was more expensive than the No. 3 Copal. Don't know by how much. Ultimately the Copal prevailed in the marketplace. Of course now the Copal line is no longer made either.
David
Infinity in lens design isn’t at the other end of the universe. It’s some arbitrary multiple of the focal length, decided by the lens designer, presumably where diffraction makes “true” infinity and the arbitrary number indistinguishable. Introducing infinity into calculations seems to create all sorts of difficulties for mathematicians.
Other members of the forum may have more precise information.
I too am surprised that a 240mm lens won’t focus on a normal camera, unless it has bag bellows.
It might just be the play of light in your pic but did your lens come with a spacer ring to be used between the lens shutter and lensboard?
And if so, is it fitted?
Because in your pic the shutter and lensboard look mighty close and this will interfere and could create problems with the lens aperture function.
Would that be a thin shim with an internal diameter that just clears the thread of the front cell?
I'll check that when I finish work but I do recall it falling on the table when I dismantled the assembly to fit the lens board.
Me too.
The infinity stops appear to be as far forward as they can go unless I need to remove them completely?
I had this problem with a 360mm Nikon on my Rittreck, I could just reach the last bit at infinity, I just made and used a top hat lens board.
This is not a lens shim!
This is a relatively broad ring that permits free movement of the aperture mechanism when the lens is attached to the lensboard.
It slips over the rear lens threads, allowing clearance for the aperture mechanism and lives between the lens and lensboard.
So lens, spacer ring, lensboard, retaining ring.
