No. You don't wish the front standard plus lens to accidentally slide off the focussing rail.Me too.
The infinity stops appear to be as far forward as they can go unless I need to remove them completely?
This is the best option.I had this problem with a 360mm Nikon on my Rittreck, I could just reach the last bit at infinity, I just made and used a top hat lens board.
I'm sure we are talking about the same thing I just used the word shim.This is not a lens shim!
This is a relatively broad ring that permits free movement of the aperture mechanism when the lens is attached to the lensboard.
It slips over the rear lens threads, allowing clearance for the aperture mechanism and lives between the lens and lensboard.
So lens, spacer ring, lensboard, retaining ring.
Good plan.No. You don't wish the front standard plus lens to accidentally slide off the focussing rail.
The last version of the No. 3 Compur increased the top speed from 1/200 to 1/250. This may have been the result of a new sort of main spring, not sure of that. Also the last version added a shutter speed scale to the front of the shutter. The diaphragm on your shutter should have click stops in steps of 1/3 of a stop.
The No. 3 Compur was more expensive than the No. 3 Copal. Don't know by how much. Ultimately the Copal prevailed in the marketplace. Of course now the Copal line is no longer made either.
David
My copy of the lens does not appear to have a spacer.This is not a lens shim!
No, definitely not a lemon.My copy of the lens does not appear to have a spacer.
All of the functions work as expected with no interference at the interface points (lens board/aperture lever/anything else).
HAVE I BOUGHT A LEMON?
Here are some threads about spacer rings (and others unfortunately)
https://www.largeformatphotography.info/forum/search.php?searchid=14894211
If it works, it works.![]()
Sorry, the link does not work.No, definitely not a lemon.
This link appears to be dead as well.No, definitely not a lemon.
