Show Us Your Camera
Matt, I am not sure why you want a plywood insert that will fix to the metal ring and turn. To my mind a better option would be to remove all the metal and fix a plywood sheet directly onto the wooden base of the camera.
Not so easily reversable if you wanted to use legs? The guy has five Sandersons and could have one base to work with all of them?
I have a reprint of a book from around 1901 on building cameras, I think it has something on making an adapter for those tripod rings.
It's online as a PDF, and the reprint is from that PDF (not vice versa). Took some finding "Paul H Hasluck", Photographic Cameras and Accessories, but alas it's the other way around the adapters are for using separate tripod legs with cameras with a 1/4" tripod socket.
A little lateral thinking is needed.
I have one of the adapters somewhere sort of a tricorn thing with metal pegs like the tripod legs at each tri , too small for the cameras I have , and I cannot see how they would fit into the ring lugs, the wooden legs fit by being under compression and have a metal wedge locking each top pair of struts they are very secure , does make the whole lot resemble a large set of bagpipes .
I remember you could get tables to pop projectors onto tripods bit bulky, Would need to be very careful using any screws into the base of the camera very high risk of splitting so I would drill through and bolt , or clamp from the inside.
For me I am happy to use the original legs as I have got the hang of attaching the extended legs to the closed camera but it is a fiddle if on the move to multiple stations as carrying the attached camera and legs is not practical.
Testing brass lenses with my Graflex Super D. I had the front modified to accept lens boards.The iris clamp works great.
