Show Us Your Camera
Matt, I am not sure why you want a plywood insert that will fix to the metal ring and turn. To my mind a better option would be to remove all the metal and fix a plywood sheet directly onto the wooden base of the camera.
Not so easily reversable if you wanted to use legs? The guy has five Sandersons and could have one base to work with all of them?
I have a reprint of a book from around 1901 on building cameras, I think it has something on making an adapter for those tripod rings.
It's online as a PDF, and the reprint is from that PDF (not vice versa). Took some finding "Paul H Hasluck", Photographic Cameras and Accessories, but alas it's the other way around the adapters are for using separate tripod legs with cameras with a 1/4" tripod socket.
A little lateral thinking is needed.
I have one of the adapters somewhere sort of a tricorn thing with metal pegs like the tripod legs at each tri , too small for the cameras I have , and I cannot see how they would fit into the ring lugs, the wooden legs fit by being under compression and have a metal wedge locking each top pair of struts they are very secure , does make the whole lot resemble a large set of bagpipes .
I remember you could get tables to pop projectors onto tripods bit bulky, Would need to be very careful using any screws into the base of the camera very high risk of splitting so I would drill through and bolt , or clamp from the inside.
For me I am happy to use the original legs as I have got the hang of attaching the extended legs to the closed camera but it is a fiddle if on the move to multiple stations as carrying the attached camera and legs is not practical.
Did you get anything from Photographica?
Hey Nas. As I went to the photo London fair in Olympia on Sunday, I only had the last hour to look around at photographica. My aim was a nikkor 75mm f4.5 and the sinar people photography book I’ve been looking for. I found a 75mm but sadly not the nikkor it was the FUJINON f5.6. Was a good price (275 and negotiable) but I am after the nikkor. No luck on the sinar book. The wait goes on lol.
On Saturday I went to “the other photography fair” they showcased alternative photographic processes like salt printing, photogravure, platinum, cyanotype and wet plate. Much preferred Saturday. Really inspired me
Sounds great. I had an email about it but it was short notice. With some planning I might have been able to make it. Nice to hear it was a worthwhile event. Do you think it will happen again next year?
I found out via a last minute email from chiswicks auctions also. Good question. I think it will. It is very different to photolondon. just needs to more promotion.
Dallmeyer 15x12 lens on unknown 12x10 camera. The lens isn't all that heavy and I could get away without the lens support.
What's the design, focal length and aperture of the lens?
It seems huge coverage for such a relatively small package.
This is what it looks like. I don't know the design. I think it's around f9 wide open judging by the hand scratched markings.
Size wise as it's marked 15x12 it's not huge, as it's a 19½" f8 Rapid Rectilinear lens, Patented 160 years ago by JH Dallmeyer. This one is early as it was converted later to have a diaphragm. Should be 2½" diameter.
Unlike the Dallmeyer Petzvals there was only one standard Rapid Rectilinear design
This is the 1898 Dallmeyer BJP Almanac advert. Seems Dallmeyer dropped the RR lenses during WW1.
W↑D shows it's a war dept. lens. If it has a serial number you could look the date up.
So does R.E. "Royal Engineers" could be the first or second Boer War in South Africa, less likely to be WW1 as there were far better lenses available.
