8 X 10 Pinhole Build Progress # 2
John Nelson
Hello, I’m John and I’m building an 8 X 10, 120 mm pinhole camera. With the structural box assembled and the glue dried, this week I moved forward to applying the veneer to the outside of the box. The veneer serves two purposes: it will be an attractive and interesting protective outer surface, and it will cover the outer mortise & tenon corner joints and adding a layer of light-proofing.
I approached this job with zero experience, but with all the bravado of a seasoned YouTube watcher and AI web searcher. I imbibed a number of conflicting narratives, but when distilled, they pointed me toward using a clothes iron to apply the veneer using PVA glue. PVA glue is known as carpenter’s glue, usually white or yellow. There are several variants, and using heat to adhere surfaces together seems like an off label use. The idea is to spread a layer of glue on both the camera body and the back of the veneer sheet, let the glue dry for about 30 minutes, then position the veneer on the plywood box. The glue is dry so it doesn’t bond the way contact cement does. Then, using a domestic clothes iron set at “cotton”, iron the veneer from the centre outward. The heat melts the glue and it fuses the glue layers together.
I tried gluing a scrap of veneer to a test piece of wood and the result was impressively strong, smooth, and flat. Thus emboldened, I applied smooth layers of glue to the camera front and to its piece of veneer and waited until the glue was dry to the touch. With the veneer positioned, I covered it with a sheet of brown bag paper and ironed away. It only took a few seconds for the thin sheet to bond to the plywood box. I can tell you I had been quite apprehensive about this step, and I was very relieved when it worked! One thing I noticed was that there were a couple of short spots near the edge where I hadn’t applied quite enough glue, but it was quick work to squish some glue in the void and clamp it until it dried. For the remaining pieces, I put a bit extra around the edges after rolling the glue on with a little foam roller. I found that the layer of brown paper was unnecessary and there was no damage to the veneer from the hot iron.
With the oversized piece of veneer secured, I used a sharp utility knife to trim it to size against the box edges, then sanded the thin edges straight and smooth.
Why not use contact cement? I work in the furnace room in my basement, so volatile chemicals are not an option because there is often an open flame in the forced air furnace or the hot water tank. And contact cement would stink up the whole house. The same considerations will apply for the finishing phase, but that won’t start for a few days until I test some alternatives.
The other news is that the tripod mounting flange from Amazon finally arrived. That was one piece I fretted about a few weeks ago, thinking that I would need to learn CAD drawing skills and send a drawing out to the CNC service to be custom machined. But with a bit of creative searching, I found just the thing for only $19 CDN.
Thank you for reading this far. Here is a picture of the tripod flange, the raw veneered camera box (unsanded, unfinished) and two photos of the glue up process.
Some rather late advice... It’s possible to make a tripod mount by recessing the appropriate size nut into the body and fixing a plate, with an appropriate hole, over it. This can give a larger contact surface with the tripod head. Easy to embed two nuts to give different sizes if you have more than one tripod. Depending on the dimensions, you may need a light-proof masking plate inside.
Thank you David, that is a really interesting suggestion. I mulled it over all morning, and if (when) I build Pinhole Mark II, the “inverted nut” concept will be high on my list of ways to fasten the camera to a tripod.
I saw a YouTube (again with the YouTube!) video where a fellow crudely welded a nut to a steel washer. Yucch. It incorrectly poisoned my mind to the whole nut idea. Nuts to nuts I foolishly said.
But with the nut silver soldered to the inside of a handsome brass disk… then recessed into the camera body… now that sounds very promising. One might consider using a cap nut to prevent the tripod screw from penetrating too far and damaging the camera body. The top of said cap nut or acorn nut might need to protrude into the box a little but a squish of black sealing goo would ensure light tightness.
Thank you!
You’ve taken the idea a good deal further. Might I suggest matching the metal plate to the size of your tripod head?
John, there is a good chance that the veneer could come loose along the edges where it is unprotected. Normal practice is to cut rebates along all the edges ( I think they are called rabbets in North America) and glue in protective strips of hardwood, about 3mm square in section. You should be able to get these in various woods from a musical instrument materials supplier.
I made a wooden shelf for my whole plate tailboard camera to sit on. The base of the camera is too thin to recess threaded nuts. I used a cheese board surrounded by wood to match the size of my Majestic 1200 tripod head. Not as elegant as recessed nuts but it works perfectly and is very strong when my 12 3/4 inch Cooke Portrait lens (5 KG) is hanging on the front of the camera.
Dear Alan, thank you for your insights. You are clearly a talented and skilled luthier; from my humble perspective as a mere YouTube trained builder, you won’t be surprised that I find inspiration from a young woman from Kiev (recently relocated to Portugal) who repairs hideously damaged guitars to perfection. Your suggestion of an inlaid edge banding answers two needs - physical stability and artistic beauty, especially if the edge banding is of a contrasting colour. With respect to “rebate” vs. “rabbet”, Shaw supposedly characterized ours as two cultures divided by a common language! I will remember your ideas when I start Pinhole Mark II.
Thank you Nas, that is a workmanlike and very functional solution. My camera box material thickness was a dimension that required some compromise: not so thin that it would not support a tripod mounting plate, not so thick that it would be too heavy, and would require a very large hole in front of the pinhole to capture the width of field for the 8 X 10 diagonal film measurement. 9 mm seemed a good compromise. It’s not ungainly or overly heavy, and the port needs to be only 31 mm in diameter. Time will tell!
John, how are you going to fix the film holder to the back of the camera? Apologies if you have already covered this, and I missed it.
Hi Alan, thank you for your question. When the finishing is done (subject of next Progress Report!) I will decamp to my brother’s lighting fixture factory where he has kindly offered me the use of sheet metal equipment. I’ll make brass angle which will form a channel into which the film holder will slide, and a brass shutter flap. All to be polished and affixed with polished brass screws.
Thank you!
I've restored a lot of vintage Wood & Brass cameras over the past 20 years, many use tripod rings, those that don't have a brass tripod fitting. These are smaller diameter
With British cameras these are similar to the fitting here, except brass and smaller in diameter, they are fitted to the top side of the base board, usually only the narrower bit is sunk through the wood, spreads the load. Larger cameras and US tailboard field cameras typically have a thicker base-board and similar fittings are counter sunk.
Thank you Ian, I like the idea of countersinking the tripod mounting flange - an elegant technique! Another item to add to the Pinhole Mark II list!
