Nikkor W-150mm f/5.6 Lensboard Query
If I am able to get all this stuff to work, I’ll start looking around for something a little wider. I thought perhaps a 90mm would be the next step. I can go down to 75mm on the Intrepid I am told. 65 mm requires a recessed lens board, which sounds like it might be awkward. I’m primarily a landscape guy.
As others have commented, the F/6.3 Angulon only just covers 5x4, though in practice I've only had an issue when using front standard shifts and a filter. However one other thing to be aware of is that at least on my Intrepid Mk3.5 (Mk3 body + Mk4 base) it won't quite focus to infinity on a flat lens board -- I cut away part of the ferrule that holds the focussing mechanism to allow the standards to get a little closer. I have since found a Super Angulon F/8 (I do use raised FS & filter quite frequently), and that has a little more room for focussing.
How interesting. Is that because there is insufficient focus travel on the Intrepid?
The comment by gnomus is interesting, there was certainly full focus when using the 90mm Angulon on an MPP MkVll, but it may be that on an Intrepid Mk3 (a camera I’m not familiar with) recessed panel is needed?
I certainly need a recessed panel with my 90mm Super Angulon on my Linhof.
I have no issues with this lens my Intrepid MkII (or any other of my 5x4 cameras) so it looks as though the rear screw focussing mechanism is an issue with the MkIV base. :mad:
With the original Mk 3. I needed to slide the rear standard forward, but that movement is not present on the Mk4 base. It's only about 1mm short (maybe even less) on the MK4 base.
There's something wrong. Your MPP MkVII uses a cont'd board for a 90mm opposite to recessed, but that's so the standard sits on the inner part of the focus track, it doesn't need to be though. It's about taking the standard to one side or the other of the drop bed when it's dropped.
I see it all, and use both as I use and restore a lot of cameras a:D
Ian I bow to your more recent knowledge, it’s 50 years since I used the MPP and could well be my memory is playing tricks, I felt sure the Angulon was mounted on a recessed panel, but we exchanged the MPP for a Sinar monorail in 1968 with bag bellows for w/a use, so I am happy to accept I’m wrong on this. I bought my Linhof in the early 70’s, which I am still using, and this certainly does use a recessed panel for the 90mm.
As a further comment, I think that when using the 75mm w/a the MPP is still superior to the Linhof in that the focus bed is still effective with these wider angle lenses where the Linhof isn’t. I have occasionally thought about buying the additional w/a focus assembly that is available for the Linhof but as I’m now retired and use the camera for pleasure rather than profit, I decided to live with the inconvenience.
I would imagine the cost of the wide angle focus mechanism would be extortionate?
It might be a better option to look for a used MT2000 or MT3000 which have the internal w/a focus mechanism built in?
Mike, there is a Chinese unit that works out at about. £400 specifically made for the Linhof, nice to have but do I really need one?
Besides I’m not really looking to add to my kit, it’s served me well for over 40 years and as I said I’m retired and just use it for pleasure now.
I've just dug out my Intrepid Mark I and it has no difficulty in focusing a 75mm lens at infinity. 90mm would present no problem at all. Is the front standard in the rearmost hole? Haven't handled any of the later models so my observations may be useless.
...and when I had an MPP (I forget which version) wide angle lenses sat on a raised conical board, the front standard was racked back onto the short rails inside the body and the baseboard dropped to keep it out of the field of view. Although it seemed clumsy, it did work.
Hi Praxinscope. Since we've got into this issue in detail, I thought I should make it clear that I was not suggesting the Intrepid could not focus with the 90mm Angulon. I don't even have the camera as yet - I'm on the waiting list. My post was a response to James T's comment (bolded and underlined for convenience below):
As others have commented, the F/6.3 Angulon only just covers 5x4, though in practice I've only had an issue when using front standard shifts and a filter. However one other thing to be aware of is that at least on my Intrepid Mk3.5 (Mk3 body + Mk4 base) it won't quite focus to infinity on a flat lens board [my emphasis] -- I cut away part of the ferrule that holds the focussing mechanism to allow the standards to get a little closer. I have since found a Super Angulon F/8 (I do use raised FS & filter quite frequently), and that has a little more room for focussing.
I was merely asking James if this was due to lack of focus travel. The only reason I know about 'focus-travel', is that it is one of the issues you can run into when trying to image through telescopes (something that I do quite a lot), and I wondered if this was what James was describing. Apologies if that has caused any confusion.
Steve
While I've only owned and used MPP MicroTechnicals for two or three years I have used LF cameras for 42/3 years and was aware what was around earlier.
I was very surprised when I first saw then MPP coned extension board for the 90mm Angulon lenses, having used them it makes sense.
I only have one recessed lens and it's an issue, no shutter.
OK, it's not strictly what we normally call a Copal #0, it's a Wista 0.0 Press shutter modified by Copal for Wista. The second cable release socket connected the shutter to the camera back (not sure which Wista models) and the lens would automatically stop down when a film holder was inserted.
Musashino was a camera manufacturer in Tokyo they mad Rittrek cameras after WWII, a very nice compact and light metal bodied 7x5 field camera and a 6x6 SLR, also Shanel shutters. They had set up a seperate distribution company Rittrek Trading. The manufacturing side went bankrupt in 1969, production of the Rittrek 66 was taken over by Norita, Rittrek trading took over filed camera production forming a a new company Wista in 1972.
In the 1970'snand 80's Wistar had their own rebranded range of Wistar lenses, mostly made by Nikon, as well as their Wista press shutters modified for them by Copal.
Like the Ibsor and later Prontor press shutters the Copal & Wista press shutters are self cocking, this limits the top shutter speed usually to 1/125. While this helps make them faster to use than a standard Copal/Compur shutter you still have to stop the lens down manually after focusing, the Wista press shutter adds auto aperture. Quite outside Japan and the US.
If I do decide to change the lens board (to one that is not off-centred), would it be a Copal 0 board that I would need? (Intrepid offer Copal #0, #1 and #3.)
Yes a Copal #0, I get lens boards from China, ecbuyonlie2008, under £18 inc postage.
Thanks (again) Ian. The Intrepid boards are £20 and (one would hope) are guaranteed to fit. So I might just go with them this time.
Steve
Steve
Steve, further to Ian's post. I have bought boards from this seller https://www.ebay.co.uk/itm/Copal-0-...771276?hash=item3fc5efde8c:g:eQ8AAOSwUF1c~qZx and they are made by Shen Hao and I can confirm that they fit both my Intrepid MkII and my Shen Hao.
The important part is the Chinese boards fit all the cameras as do genuine Wista, Linhof. Toyo boards, and they fit Intrepids but do we know if that's vice versa.
These are good points. They're a little bit cheaper than the Intrepid boards too. I've ordered one.
Thanks again, Keith. That is a significant size (and no doubt weight) difference. One of the reasons for me getting the 4x5 is so that I can try tilting the lens to get foreground to background in focus. Am I correct in thinking that the 'Super' moniker relates to the field of coverage? And how much tilt would I be able to get away with using the smaller lens? I'd much rather go smaller if I can get away with it.
I've also been reading about Fuji and Nikon 90mm lenses. Any experiences of them?
Schneider used to have lots of information on their website on their old lenses , amongst other things , but has all been dropped.
Luckily this information is still available elsewhere .
If you look on the way back machine , it's been saved there .
See this link ;
Select which range of lens your interested in , then select the specific lens .
The information on coverage and how much movement is available on different formats (5"x4" , 7"X5" , 10"x8" , 13x18cm etc) .
Other specifications are there as well , overall dimensions , filter size , shutter size and so on .
All helps when your researching a choice of lenses .
I've been looking at the Schneiders, but have yet to see one that grabs (reasonable price and so on). Any thoughts on the Fuji 90mm? It's f/8 which might make things a little dark for focussing I'm guessing. But what about its optical qualities?
