Sort of. It would seem that DPP did a non-destructive edit to the JPEG file, but added the following editing parameters to the JPEG file…
Code:
[CanonVRD] DR4 Camera Model : Unknown (0)
[CanonVRD] Rotation : 0
[CanonVRD] Angle Adj : 0
[CanonVRD] Check Mark : Clear
[CanonVRD] Work Color Space : sRGB
[CanonVRD] Sharpness Adj : Sharpness
[CanonVRD] Sharpness Adj On : Yes
[CanonVRD] Sharpness Strength : 1
[CanonVRD] Tone Curve Color Space : RGB
[CanonVRD] Tone Curve Shape : Curve
[CanonVRD] Tone Curve Input Range : 5 250
[CanonVRD] Tone Curve Output Range : 0 255
[CanonVRD] RGB Curve Points : (5,0) (250,255)
[CanonVRD] Tone Curve X : 250
[CanonVRD] Tone Curve Y : 255
[CanonVRD] Red Curve Points : (0,0) (255,255)
[CanonVRD] Green Curve Points : (0,0) (255,255)
[CanonVRD] Blue Curve Points : (0,0) (255,255)
[CanonVRD] Tone Curve Original : No
[CanonVRD] Tone Curve Brightness : 0
[CanonVRD] Tone Curve Contrast : 3
[CanonVRD] Auto Lighting Optimizer : Standard
[CanonVRD] Auto Lighting Optimizer On : Yes
[CanonVRD] Luminance Noise Reduction : 0
[CanonVRD] Chrominance Noise Reduction : 0
[CanonVRD] Color Moire Reduction : 2
[CanonVRD] Color Moire Reduction On : Yes
[CanonVRD] Color Hue : 0
[CanonVRD] Saturation Adj : 100
[CanonVRD] Red HSL : 0 -10 0
[CanonVRD] Orange HSL : 0 -10 0
[CanonVRD] Yellow HSL : 0 -10 0
[CanonVRD] Green HSL : 0 -10 0
[CanonVRD] Aqua HSL : 0 -10 0
[CanonVRD] Blue HSL : 0 -10 0
[CanonVRD] Purple HSL : 0 -10 0
[CanonVRD] Magenta HSL : 0 -10 0
[CanonVRD] Crop Aspect Ratio : Free
[CanonVRD] Crop Aspect Ratio Custom : 1.5 1
[CanonVRD] Crop Active : No
[CanonVRD] Crop Rotated Original Width : 0
[CanonVRD] Crop Rotated Original Height : 0
[CanonVRD] Crop X : 0
[CanonVRD] Crop Y : 0
[CanonVRD] Crop Width : 0
[CanonVRD] Crop Height : 0
[CanonVRD] Crop Rotation : 9999
[CanonVRD] Crop Original Width : 0
[CanonVRD] Crop Original Height : 0
[CanonVRD] Stamp Tool Count : 0
[CanonVRD] Lens Focal Length : 0
But, what it didn't do is rewrite the image information because, like some other software, DPP combines the edited image with the change parameters, so you can see the result, but only in DPP.
In order to see the edited file in any other viewer, you are going to have to export the edited, combined, file from DPP. The editing parameters I quoted are only usable in Canon's software.
