So each fractional exposure creates + over exposure?
If I made eight exposures I would have to reduce my time by -3 stops?
Good idea to make the point of not forgetting reciprocity failure. Not sure if the attached method allows for reciprocity. Do you add the reciprocity first, ex.?No, because of reciprocity failure, more like -2½ stops.
When I went to Bristol (feb for martin parrs exhibition I shot a whole roll on my mamiya 7ii double exposure. What I found is if you have the sky in the scene the negative builds up density to the point where it starts losing detail. This happens I learnt when you layer one frame 16 times or above, I mostly do 16 and 32.Good idea to make the point of not forgetting reciprocity failure. Not sure if the attached method allows for reciprocity. Do you add the reciprocity first, ex.?
Metered exposure 2secs
Add 2s for reciprocity = 4s
4s 1 exposure
2s 2 exposures
1s 4 exp.
1/2s 8 exp
1/4s 16 exp.
how much would I reduce the exposure?
I found this
I like both but I would do a square crop and get rid of the post on the left.I made a couple of experiments last week to see how best to make these type of image with the work I make, as I’d had it in my mind to do it with this subject for 6 months or so. Initially I was thinking about making them at dusk and using off camera flash, to give more light and freeze the movement of people and flags in the image. However this is a structure I am doing some heritage professional work on for the local council at the moment and wanted an image for the front page of a report, so thought I may as well try things out.
This is 5x7 FP4 with a 210mm Symmar-S 5.6 lens on a Sinar P, TTB Metol dev.
The first was 6 or 7 shots at 1/60th at F45. (both the minimum aperture and maximum shutter speed of the Sinar copal shutter) metered for an exposure of 1/15th
The second was 10 shots same exposure and this kind of looses the effect I was after, although these are quick scans and I look forward to a little more play in the darkroom.
I’ve wondered about using a red filter for an extra few stops to play with.
Thoughts and suggestions welcome and making better notes already on my list.
Nice. i have found when you use a tripod you make a structure bone sharp but people move so slow shutters work. Ill dig for a example of mine. Do you want to see people in the frame? Distance also play a great part to this effect.I made a couple of experiments last week to see how best to make these type of image with the work I make, as I’d had it in my mind to do it with this subject for 6 months or so. Initially I was thinking about making them at dusk and using off camera flash, to give more light and freeze the movement of people and flags in the image. However this is a structure I am doing some heritage professional work on for the local council at the moment and wanted an image for the front page of a report, so thought I may as well try things out.
Amazing Marty. This is such a great idea. The build of density when you layer 16+ is a factor to consider as I’m learning. This photography is something I love doing so would be willing to help out if you would like.I never thought I'd ever say this in my lifetime but "I've made an app."
Based on this thread, I tried to workout some way for me to manage the process of multiple or fragmented exposures on one piece of film.
Here is a simplified overview of my process.
Step 1 - How many exposures do I want to make?
Anywhere from 2-64
Step 2 - Do I want all of the exposures to be the same OR do I want the exposures to be weighted differently?
Fully customisable
Step 3 - How do I measure and calculate exposure?
Both phone and handheld metering
Step 4 - How do I time and keep track of the exposures?
Built-in timer and exposure counter
Here are some screenshots showing the functionalities for both identical exposures as weighted/customised exposures.
Disclaimer:
No I'm not a developer and I've never built an app before!
It's still work in progress and has never been put to use.
Very nice. Is the first one Bristol Docks?so I got help on getting the pictures to upload on here. Recents Tests. Handheld.
X16 layers on one frame (cropped to 1.1.55) Foma 100 ei50 HC110 and rodinal mix.
x32 layer FP4 ei64 no crop Id11 1+1
Test of same frame but shooting normal, x2, x4,x8,x16,x32. no edit just used ians DBW scanning software to scan negative and then convert to positive. FP4 EI64 developed in id11 1+1. What i learnt from this test is the density builds up once you reach 16 layers. you either reduce development or cut back some layers. I spot metered to place the darkest of the canal gate in zone 3.
Sorry for delay.
It is. I went to Bristol for martin parr’s celebration of his life event.Very nice. Is the first one Bristol Docks?
I was there this afternoon, the current exhibition is well worth a look https://martinparrfoundation.org/exhibitions/dark-tales/It is. I went to Bristol for martin parr’s celebration of his life event.
Oh I’ll check this out thanksI was there this afternoon, the current exhibition is well worth a look https://martinparrfoundation.org/exhibitions/dark-tales/
Cheers. I rather like it myself. Going to print it. Would be interesting to see how it feels in print.I find this one extraordinary.![]()
